Question about Kyocera Cell Phones
Kyocera cell phone is dropping calls
Phone is not connecting after dialing and phone is dropping calls
    New Friend:
  • 28 Answers
You could be in a location with bad coverage/reception (few or no bars). Try moving to a location with better coverage.
You might also need to reboot your phone. Try turning it off by holding down your power button (depending on your model you might need to select "turn off" from a menu after that). Remove your battery and wait 30 seconds to a minute. Replace your battery and turn your phone back on. Wait for it to finish booting and try your call again. Hope this helps!
Posted on Aug 15, 2014
5 Suggested Answers
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
Posted on Dec 14, 2008
Bajanguru
  • 7752 Answers
SOURCE: No dial tone at my end when I ring a certain number even though the number I'm calling is ringing, also really slow to connect. all other numbers are fine
dial tone but mobiles ahve no dial tone when making or receiving calls.....
Posted on May 30, 2009
  • 20 Answers
SOURCE: ihave a kyocera phantom cell phone i cant remember unlock code
go to nearest kyocera service center and unlock
Posted on Aug 26, 2009
SOURCE: Verizon Razzle cell phone will not make calls properly after
did you drop anything on it, like an egg. i did one time and it blocked the microphone of my samsung sch a850.
i had to get a new phone. if you didn't drop anything on it call verizon with another phone and say my calling isn't working. one time after my phone got reactivated and it could not send picture messages so i called verizon and they fixed it right up?
Posted on Mar 30, 2010
KYOCERA Event dont hang up
firmware issue..try turning off phone..take out battery..put it back then power on..nothing happens? back up files then master reset phone..still having same prob???call 18883221122 ask for replacement phone or battery..will be free if under warranty or you will be offered a discounted replacement phone..im a customer support representative..
Apr 12, 2014 | Virgin Mobile USA Kyocera Event
How do you forward your calls from a Kyocera jax to another cell phone?
Here is the information that I found for you, if you need better instructions, you should probably contact your cell provider. However, this should be all you need:
To forward dial *72# ***-***-XXXX (the number you want to forward to) send.
To unforward *720# send.
After you dial, press send and you should hear two short beeps. You can then hang up and you should be set.
Thanks and good luck!!
EJ Kudelka
Mar 03, 2012 | Cell Phones
Jan 23, 2010 | Cell Phones
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
Cannot receive faxes. Fax is set to auto receive and there is dial tone in machine. Any other ideas?
Call a cell phone from the machine and verify this is the correct fax phone number that shows up
You must be absolutely sure you have an ANALOG phone line. There is no other cure.
Kyocera fax systems are very picky.
Jun 04, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera candid ii will not send/receive calls.
you have to deactivate your call divert service for all
May 19, 2009 | Kyocera Candid KX16 Cellular Phone
Kyocera phone went out and cant see screen how do i forward my me
Try to check with Kyocera's website to see if there is a software update for your phone. If not, make sure no water damage has been done to the phone or if you have dropped it this can cause it as well. Dial *228 then reset your phone (turn it off then back on) try that, if that does not work try calling your phone company to get a replacement phone at no cost because it sounds like a Manufacturer problem.
Mar 18, 2009 | Kyocera Strobe K612B Cellular Phone
White Screen. -_-;
well i had the sameproblem but just go to the store and find out wats wrong the soft ware has a problem but they repaired mine for cheap
Aug 27, 2008 | Kyocera Switchback KX21 Cellular Phone
Phone i cant do anything with it
You hit an internal wire on your Circuit board, you need to get a new cell phone, or send it into the manufactorer.
Jul 14, 2008 | Kyocera Slider Remix KX5 / Sonic Cellular...
Cell Phones Logo
27 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
