Question about Royal 29140X PX100MX Cross-Cut Shredder
Royal mc100mx wont stop running unless i turn it off but sensor should stop it
  • 20 Answers
Dear Michael,
Here is some generic information about shredders that may help you.
Most of the shredders have a micro switch that "senses" if the paper has been introduced to the shredding slot. These micro switches are activated by a little arm/leveler that touches the paper and activates de contact inside the shredder housing. Also, note that some shredders may have an optical sensor that may be "clogged" with paper dust.
If you shredder does not stop, the sensor may be stuck in a on position, or, in case it has optical sensor may be detecting dust or a little piece of paper may be blocking the optical sensor and keeping the motor running.
I hope this gives you some light in further investigating your problem.
RC
Posted on Jun 17, 2014
Shredder turns on but wont do anything
When you say it turns ON but wont do anything do you mean that the motor dosnt run??? or that it runs but dosn't shred paper.??? In either case you have either broken gears or defective pcb related components...contact Royal at 1-800-524-0799 to see if parts are available for this model.
Jan 31, 2011 | Royal AG300X Shredder
It Just stopped running. I waited quite awhile before trying again and still it will not turn on.
It would not have stopped running unless it was shredding paper...so I assume you jammed it to cause it to stop...try running it in reverse to remove the jammed paper while you pull the paper back out to assist the motor. If the machine is dead and will not even run in reverse the you have probably fried the PCB inside...give Royal a call at 1-800-524-0799 for parts assistance......I assume its a Royal as this call was posted in the Royal section.
Sep 14, 2010 | Office Equipment & Supplies
Only works in reverse... ready light not on
If it runs in reverse then the gears and motor are probably ok....if the ready light will not come on then probably the pcb inside....call Royal at 1-800-524-0799 for parts assistance.
Sep 08, 2010 | Royal MC100MX Shredder
A Royal crosscut shredder that usually only runs in reverse
in the middle of the paper enterance clean sensor
May 22, 2010 | Royal CIA 12X Shredder
Royal vf700 paper shredder wont turn on
If it wont run forward or backwards then probably the pcb inside is fried...call Royal at 1-800-524-0799 for parts assistance.
Jan 05, 2010 | Royal VF700 Cross-Cut Shredder
Royal CIA12 crosscut shredder overload light came on.
Unplug immediately and wait 20 mins to see if motor will "cool-down"...when plugged back in hopefully the Overload light will be OFF....unless you have it completely jammed up in which case try running it in reverse if the overload light is OFF.
If the overload light wont go out you may need pcb...contact Royal at 1-800-524-0799 for further parts assistance.
Nov 24, 2009 | Royal Office Equipment & Supplies
My 1989 oldsmobile 88 royale wont start just pops and back fires there is normal spark and injectors are pulsing, there is correct fuel pressure and everything crank sensor if fine, could it be the cars...
It's under a cover (on the order of 6' wide x 12" high) on the top front face of the engine. It's quite a job to remove this cover. A less laborious method to determine if belt is broken is to run a compression test on the cylinders.
You may get someone to come to the vehicle to do this, else it'll have to be towed (unless you have the equipment to do it yourself).
But you can't use the car in its current condition, so maybe towing to a garage is a reasonable option...?
Charlie
Aug 20, 2009 | 1989 Oldsmobile Eighty Eight Royale
Royal 160MX continuously runs
I used alcohol on a q-tip to clean the sensor. I completely dissasembled my unit only to find it was unnecessary. The senosors are in the middle of the slot above the metal roller bars. There is a small 1/16" photo sendor on either side of the slot in the middle. they look like small holes in a square area. (Royal 15mx)
Apr 20, 2009 | Royal 160MX Shredder
Royal VF1012mx Shredder Runs and will not shutoff
Try using compressed air to blow off the sensors , as they may have paper dust on them, I f that doesn't work try Alcohol and a Q tip to clean the sensors, as alcohol leaves no residue.
Please be sure to unplug the machine before attempting any repairs.
Apr 18, 2009 | Office Equipment & Supplies
Royal 29140X PX100MX Cross-Cut Shredder Logo
82 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
