Question about Kenmore Water Dispensing & Filtration
Water overflowing on Kenmore 90 Series
Water level overflowing, have to use reset button
AlmostBob
  • 550 Answers
SOURCE: Kenmore 90 series washing machine
Follow all jsrocks tests,
but Before replacing the pressure switch there are more tests of function
Blow any water out of the air tube, it should be empty when the washer is empty, water remaining in the tube messes up the pressure sensing(usually makes water level lower so doubt this is the fault)
Kenmore pressure switches are adjustable, the adjustment is hidden.
An internal spring stretches over time and does not react properly.
to test whether just the adjustment is required,
  1. remove the water level knob from the front side of console
  2. depress the lock tab at the right side of water level sensor body where it contacts the back side of the console and rotate counter clockwise 45degrees
  3. withdraw water level sensor body
  4. adjacent to shaft for the knob is 1/8inch bolt head, turn clockwise to raise, counter clockwise to lower water level.
  5. washer can be operated with the console open and the level body removed
  6. test, adjust, test adjust.
  7. if no effect replace water level sensor body
Posted on Jun 04, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a 90 series Kenmore washing machine model
The pressure switch (also called the "water level switch") determines the point at which the water level should turn off. It will be located behind the water level or load size knob inside the control panel. You can view it by removing the back of the control panel. NOTE: Make sure you UNPLUG the washer before removing the back of the control panel). If you have tried various load levels and the water still cuts off at the same point every time, you may have a pressure switch that is malfunctioning or, an air dome hose that has something clogged or kinked, causing the switch to trip early.
The air dome hose is a clear plastic hose that attaches to the pressure switch and runs down to the right hand side of the wash tub to what is called the air dome. Pressure builds up inside this air dome as the water level rises and is sensed by the pressure switch. Depending on the water level you have selected, the switch will cut off the inlet water at the prescribed level. You need to take a look at the entire length of the air dome hose to make sure it is not kinked or clogged. To do this you need to remove the exterior washer case. It sounds intimidating, but its actually a simple process. Just follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
The air dome hose will be attached on the lower right hand side of the wash tub. Follow the entire length of this hose and make it is not kinked or pinched anywhere. Also make sure there's nothing in it like lint or insects (I've seen it happen).
To re-install the washer case, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If any of these preliminary steps don't work, you may have to replace the switch. Replacements can be purchased on line at appliancepartspros.com for about $22. The part number is 3366845. Just use the "Search by Part Number" feature.
NOTE: Another problem that causes the washer not to fill properly is called siphoning. It comes from improperly installing the drain line which causes water to siphon out of the wash tub as it tries to fill. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Usually when a washer siphons, however, it never reaches the cut off stage and continually tries to fill. Or, it fills and shuts off, but loses water during the wash and starts filling again. I don't know if these are the symptoms you are experiencing, but it may be worth the effort to double check your drain line to make sure you have a proper air gap. You may avoid having to replace parts.
If you have questions along the way, please let me know. I hope this information is helpful to you.
Posted on May 04, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
Posted on May 10, 2009
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
How to fix a Kenmore 90 Series when the water keeps running?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this will help you to fix your washer,
Gene
Aug 09, 2011 | Kenmore 22422 Top Load Washer
My kenmore 90 series washer machine is overflowing. i dont know why the water control button seems to not be working. what should i do?
Turn the water off in the back of the washer where the hoses hook up...
Then check this tip out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 23, 2010 | Washing Machines
Kenmore Series 90 top loading washing does not fill with water
Well you eliminated the fill valve when you said it does fill with water. More than likely its a bad connection on the control board. I wouldn't betmy paycheck on it but thats where I'd start. Take the cover off the control board and while machine is on being really careful wiggle each wire until the water starts in the tub and you have found the problem.
Aug 23, 2009 | GE WVSR1060A Top Load Washer
Washer keeps filling up with hot water
Hi
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Washing Machines
Washer water wont stop running and switch to wash. It overflowed
sounds like a bad water valve. Try disconnecting for a few minutes. If problem continues, the solenoid on the water valve is staying open which means the circuit is not opening. Replace valve.
Jun 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 90 wont fill up to large load level
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as "siphoning". This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 18, 2009 | Kenmore 24032\24036 Top Load Washer
I have a kenmore washer 80 series that over flowes help please
I had the same problem with a 90 series and there is a small hose connected to the water level knob that had slipped off.
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Water Dispensing & Filtration Logo
70 people viewed this question
Top Kenmore Water Dispensing & Filtration Experts
Bill Boyd
john h
Dennis
Are you a Kenmore Water Dispensing and Filtration Expert? Answer questions, earn points and help others
