Question about Lexmark Prospect Pro 205 All-in-one Printer brand New
My pro205 will not scan or fax without refilling the ink whats up
I can not scan or fax because my ink is low whats up with this
3 Suggested Answers
vegakitten20
  • 685 Answers
SOURCE: refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Posted on Jan 08, 2009
yboyandrei
  • 828 Answers
SOURCE: ink low massege after refill
dont worry its always like that, sometimes the refill ink from tis design are normally recognizing its slow but after all when you keep using that and print more... it will not prompt again...
Posted on Jun 20, 2009
I am having problem on setup of the fax I have a line for fax
The orignal ink cartridges supplied with these machines are fairly low capacity. You can get XL versions which contain 2-3 times as much ink. If you are using refilled cartridges, you may find the Fax module can not tolerate refills. There is a way to reset the machine to ignore the ink level counter for the printer/copier functions, but the Fax module addresses the cartridges diferently for some reason.
Feb 22, 2015 | Canon PIXMA MX472 Wireless All-in-One...
How to override lexmark s415 low ink
There's no way to override the low ink warning. If one of the cartridges is out of ink, you won't be able to continue printing.
Refilled cartridges will not report or reset the ink levels.
Jan 09, 2013 | Lexmark S415 - multifunction fax / copier...
How do I reset the "Low ink" warning" after refilling ink cartridge?
When a cartridge is refilled, it can no longer register its ink level.
Apr 27, 2011 | Lexmark Prospect Pro205 Wireless...
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
Cannot send and receive fax after refilling PG-40
I own a Cartridge World ink refilling store and I think that the fax not printing is Canon's new approach to kick out refills from their all in one machines. We cannot reset the ink level indicators on these cartridges and if people can no longer print faxes if their ink says it's low, then they can never use refills if they want to use their fax machine. I think it is also a way for Canon to make more money on their ink sales by making consumers buy new ink before theirs runs out. As far as I know there is no way to fix this problem.
Feb 10, 2010 | Canon PIXMA MP530 All-In-One InkJet...
On my pixma mx310 when the ink gets low it automatically holds all faxes in memory and wont print them unless i manually do it. I have a refilled ink cartridge put in that is full and it still wont let...
Current printer cartridges usually contain a chip which doesn't let you refill without using a chip resetter. It's sensing that the cartridge is out, so it won't print. If it was reset, try cleaning the contacts, carefully, with an electronic contact cleaner, or in a pinch, alcohol.
Aug 24, 2009 | Canon PIXMA MX300 All-in-One Printer
CANON MP830 WILL NOT FAX OR SCAN IF ONE INK IS EMPTY
It's true, you need inks before you can scan or fax, It's not just Canon, All of the all in one machines are the same way. HP, Brother, Samsung, It's the drawback to having an all-in-one machine.
Jul 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Can I refill my Canon Fax JX300 cartridge?
yes you can refill the #40 cartridge mfor the JX300 - but when you put it in you will get a message saying 'ink volume unknown' and it won't do anything and the yellow light on the machine will be blinking. - to solve this problem hold the stop button down till the count of ten and the machine will work normally except you will get no low ink warning
Tony Rae
Inkspot
London, Ontario Canada
May 22, 2009 | Canon Office Equipment & Supplies
Low Ink
I get that when I have just refilled the cartridge, but I usually ignore it and it is still ok for a while; have you checked that you are using draft or normal not best settings?
Jul 29, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark Prospect Pro 205 All-in-one Printer brand New Logo
22 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
