Question about Samsung Microwave Ovens
Ministry sound dab micro system mosmc130
My sterio will not switch on at all ive even cahnged the fuse and that didnt work
    Habit-Forming:
  • 144 Answers
The transformer is bad good luck
Posted on Apr 13, 2014
My NuWave oven will not even turn on. It was working fine till I took the lid off to baste my shish ka bobs and set the top on the counter on a towel. Then it would not turn on at all after that.
  1. There are micro switches that are near the door they are responsible for keeping the microwave off when the door is open to protect you from frying your hand should you put your hand in the microwave when the microwave is on please make sure the micro switch turns on/off when the door locks/ open make sure you do the right adjustments
Apr 15, 2016 | Microwave Ovens
I changed the fuse on a Frigidare #FMT118EPB Microwave and it blew again. I checked the micro switches with a meter and they seem to work. What else could be causing the fuse to blow? Thanks.
If you put in the correct size of fuse then what it needs is to go to a qualified service tech. What would be next requires removing the covers and if you do not know what you are doing you will fry yourself.
Dec 06, 2014 | Frigidaire FMT118EPB Microwave Oven
Replaced the 20amp fuse in my microwave. Clock and all lights work but oven will not heat
one or more of the door micro switches are open or shorted..the micro switches tell the unit the door is closed and safe to use.the micro switched are marked normally open or closed..take note when replaceing them..also their is a actuator lever that tells the switch to close or open..it is plastic and connected to the door latch..it can be broken off or bent from heat,,its plastic..make sure its in place and working the micro switch
Aug 15, 2014 | Microwave Ovens
Blows fuse when you open door
Be-safe, Un-plug your microwave oven ,
Open the microwave cover ,
Close and open door few times to check the door latch(es) and switch(es).
Door switch assembly may has one or more micro switches.( Most switches are black or grey and about 1,25 in long X 3/4 in wide X 5/6 in thick with two or three wire connections).
Making sure door latch close and open these micro-switches.
You can hear the switch "clicks" when small switch pin or lever is pressed.
Sometime these door micro-switches pin or lever get stuck or broken.
You can take couple pictures before remove wires or micro switches
You can buy these switches for about 3-7 dollars online. Some web sites have video showing how to check them. (Using Volt-Ohm meter)
Jan 24, 2014 | Magic Chef MCO160UB Microwave Oven
Hi, My AEG built in micro wave has stopped working I was warming plates and it just cut out leaving an / and * on the display, I switch it off for 15mins then switched it back onit flashed 12.00 twice and...
Your microwave is not intended for use as a plate warmer. The plates may not even be microwave compatible. You may have caused the internal fuse to open or smoked the magnetron. The control board may have been affected as well.
Jan 01, 2014 | AEG MCC663 Microwave Oven
Microwave not working
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One giveaway is that you could gently lift up (and/or push down) on the door or handle to make it work.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Jan 10, 2010 | Sharp Microwave Ovens
GE SpacemakerXL Microwave Model JVM1450 It's been working great. Then put somethingin,turn it on. It ran 30sec. made a growling sound,like it was straning or slowing down,then Blew the fuse.I replace the...
SOUNDS LIKE MAYBE HIGH VOLTAGE RECTAFIER SHORTED MIC ARE VERY DANGEROUS THEY HOLD VOLTAGE EVEN WHEN UNPLUGED YOU MAY CONSIDER PRO ON THIS SORRY
Nov 06, 2009 | GE Microwave Ovens
All appears to work...fan/light/ display....but no heating occurs. I assume not a fuse problem since all but heat working. Would a bad door switch...there are three....cause this?
You have burned micro switches in the door safety interlock system. I have answered this question dozens of times here - i am surprised this answer didnt come up when you searched your problem.
There are two reasons for the heat to not come on when everything else works ... three actually, the third is expensive.
1) the capacitor has failed - dont try to service this unless and until you understand the dangers associated with this repair.
2) burned safety door switches
3) failed magnatron (they rarely fail)
remove the cover - find the door switch. Test them. With the door closed, the switches should read closed. If they read open (because they are burned because you open the door when the oven is operating) the oven doesn't know the door is closed so it will not turn the mangatron on - no magnatron - no heat.
I hope this informaation helps you ...
If you require additinal help, post to this comment.
If you are pleased, please leave positive comments
thanks for using fixya.com
a
Oct 25, 2009 | Sharp R-316FS Microwave Oven
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
