Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
My kitchenaide icemaker will not draw water from the holding supply and put it on the freezing plate......any one know why?
I'm posted the same problem about a week ago. I've talked to a local service tech and they said I need a new pump.....at $200.
Posted on Jun 18, 2009
Icemaker quit making ice .. water supply to drinking water still working ..switch is on the on position
check the fill tube that brings water into icemaker..these sometimes freeze over..if it is, defrost and order new fill valve....or, you have a fill valve thats bad..
Jan 11, 2011 | KitchenAid Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
No water in the ice maker
Pour about 2/3 cup of water into icemaker . If it freezes and dumps , and water doesn't go into icemaker , replace the water inlet valve ( the piece on the refrig that the wall waterline connects to . If it doesn't dump the water poured into it after freezing , then replace the icemaker .
Sep 06, 2009 | Maytag MFD2561HE Bottom Freezer French...
Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Nov 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker water line freezes
it is probably a faulty water valve that slowly leaks water up to the icemaker and freezing. sometimes it will freeze inside the fill tube and block the water supply completely.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker Not Making Ice BUT making a "trying" sound
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 18, 2008 | KitchenAid Architect KBRA20EMSS Bottom...
Ice maker not working lg double door, freezer draw at the bottom
Jul 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker not bringing in water
Not sure what u mean my supply valve.. that would be in back.. never seen one freeze... check the water vave in back... thats where icemaker water is supplied from.. check for continity or make test wire and put power to valve and see if water makes it to the icemaker.. only need to power for few seconds
Sep 02, 2007 | Amana ACD2232HR Side by Side Refrigerator
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
561 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
