Question about Apple iPod touch 4th Generation MP3 Player
IPod touch 4 sound output problems
When press "play" sound comes through the headphones for 1 second. I have to unplug, and re-plug-in the audio jack, and then it plays ok. There's also static when I put it on a speaker-dock. I think there's something wrong with the charging port, like it needs to be cleaned? How do I do that?
    Problem Solver:
  • 11 Answers
Try using a very fine cloth to get into the headphones port and the charging port. If all else fails, you will probably have to take it into the Apple Store :D
Posted on Apr 19, 2014
  • 6 Answers
SOURCE: charging ipod nanon 4th gen on bose sound-dock
http://www.scosche.com/products/productID/1694
Click on the link above for the solution for your problem
Posted on May 06, 2009
ipodslinger
  • 688 Answers
SOURCE: ihome won't play ipod, even
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
Posted on May 17, 2009
  • 502 Answers
SOURCE: Bad sound with static on left channel
it's usually the middle contact of the headphone jack module that loses it's elasticity and does no longer touch the headphone plug properly. if you're out of warranty, you can try to pull it back inward from the outside using a dentist tool or a strong sewing needle. if that fails you have to open the ipod touch and push the contact inward or replace the jack module.
Posted on Jun 18, 2009
kaicooper
  • 8 Answers
SOURCE: Distorted sound on blue iPod 8GB nano
make sure heasdphones are plugged in completely
Posted on Jun 19, 2009
  • 101 Answers
SOURCE: How do I fix a bad connection with the headphone
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
Posted on Jul 23, 2009
How to play my ipod through this stereo
USER GUIDE
This is the quick and easy way to adapt a standard stereo 3.5mm (1/8 inch) sound output into standard RCA plugs. Ideal for connecting your MP3 Player with a 3.5mm plug to VCR's, TV's or anything else that has RCA stereo sound inputs.
General Features:
- Fits standard 3.5mm (1/8") stereo phone jack
- Gives you two male RCA (left / right) sound outputs
- Great for converting a headphone2_bing.gif jack to standard RCA sound outputs
- 6 foot length
- Straight cable (not a coiled cable)
Generally these connectors cost between $1.00 to $5.00
Pictures to help you find them
Search google for headphone to rca adapter for more info
Hope this helps
Feb 05, 2010 | RCA RS1286 CD Shelf System
Tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
on Aug 05, 2011 | Computers & Internet
IPod headphone-socket issues.
make sure the headphones are in all the way! if you have an ipod that doesnt have the speakers built in the it might have just gone bad.
Jan 04, 2010 | Apple iPod touch Second Gen (8 GB,...
My ipod wont play sound aloud, it only works with the earphones, it used to work??
The speakers may be damaged, if you think water damage is the reason that the speakers are broken then follow these steps,
1. Unplug headphones. 2. Take you iPod to a dark place i.e room with light off. 3. Take a flash light and shine it in the headphone jack 4. Look inside the headphone jack. 5. If you see something red it is likely that your iPod got water in it and the speakers are shot.
Hope this helps, --Kaleb--
Nov 16, 2009 | Apple iPod touch
My ipod touch plays the music, but the lyrics are distorted. Tried different earphones, but it's still the same. If I move the plug a bit, it sometimes clears up.
Sounds like a bad headphone jack. Contact Apple at 1-800-275-2273 (1-800-APL-CARE) if it's under warranty. If not, find an iPod repair company to see if they can re-solder the headphone jack.
-=/ MLF /=-
Oct 21, 2009 | Apple iPod touch
IPod Touch headphone jack isn't working
I just returned my second itouch because of a similar problem. When I went back to return the third and ask for my money back....they guy pushed the headphones in all the way! I know it sounds dumb....okay its very dumb! but make sure the whole plug is in because you'll walk out of Apple looking like a PC
Sep 30, 2009 | Apple iPod touch
IPod Touch pauses itself
This can be caused by the audio jack, if it doesn't sit tight anymore, the headphone becomes disconnected for small periods of time causing the iPod to detect the headphone as unplugged, hence it will pause. Try different headphones, especially nickel plated ones and make sure there's a tight fit. If that doesn't help the jack needs replacement. If you're out of warranty you can send it to a third party iPod Repair Service.
Mar 13, 2009 | Apple iPod touch
30 GB Ipod does not produce audio
Theres an option for the max audio output, make sure thats not all the way down.
May 25, 2008 | Apple iPod MA446LL/A MP3 Player
Garmin GPS - suddenly has no sound - it just cut out
1. Are you sure the volume setting is all the way up?
2. Are you sure the sound isn't muted?
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CDplayers and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
4. If you don't hear sound from the headphone jack, most likely the audio output section is defective and you'll need to send it back to Garmin to be repaired.
Please let me know if I can be of further assistance to you.
- Jim
Mar 17, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi
3. Have you tried a pair of headphones in the headphone jack? If the headphones have sound, your internal speaker is bad. If you don't feel like sending it back for repair, you can purchase a FM transmitter like those used on IPODs and CD players and plug into your GPS's headphone jack and play the audio through your car's FM stereo.
- Jim
Feb 13, 2008 | Garmin Nuvi 660 GPS Receiver
Apple iPod touch 4th Generation MP3 Player Logo
32 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
