Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
All of a sudden it stopped making ice. the ice maker is making a grinding noise, but will not make ice.
Ive even put water in the ice maker and it will not dump the ice
  • 67 Answers
It sounds like the unit froze up and stripped a gear. The only thing to do is to replace the ice maker head unit. You can get them at just about any appliance parts place for about $90.00. and is fairly easy to replace.
Posted on Mar 22, 2014
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
  • 65 Answers
SOURCE: Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Posted on Feb 16, 2008
  • 77 Answers
SOURCE: Ice maker Stopped producing ice
What is sounds like is somehow either the water delievery system is clogged or frozen. If your getting water out of the door, then it is probably frozen. If you are able to turn off the freezer for a bit, that would be an easy way to see if that is the problem without having to deal with Whirlpool or a handyman.
Posted on Oct 17, 2008
SOURCE: Ice maker stopped dropping ice or even making ice.
whirpool model ED2GHGXMQ00 three years old quit making ice and most recently we have replaced all the water filters! David
Posted on Mar 29, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Posted on Apr 27, 2009
Why would my GE (model # TBX18SA) just stop making ice?
Is there any ice remaining in the slots of the ice maker? If not then the water control valve will need to be replaced. If the ice maker still has ice in the cube slots and does nothing then it is the ice maker that needs to be replaced. Here is the=> WR30X10093 Ice Maker for your TBX18SA and the=> WR57X10033 Water Inlet Valve
APPLIANCE 911
Mar 15, 2016 | GE Refrigerators
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
My Emerson Portable Ice Maker started makeing a loud grinding sound when pumping water -why?
Probably the bearing in the pump is shot depending on how old it is try getting it covered under warranty
Oct 29, 2012 | Emerson Im90 Portable Ice Maker
Ice maker suddenly stopped working. It makes strange noises intermittently, sometimes sounding like a Geiger counter. It no longer draws water. What can I do to diagnose & fix the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 10, 2010 | Refrigerators
Ice maker making a grinding noise. I remember a
Yes - if the noise does not stop - please re-post.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Samsung twincooling icemaker leaking water & overfreezing
probably the water valve is not shutting of completly . this will flood the tray and then run over into the bucket. try // i would replace water valve . if this does not correct prob. replace the ice mker head as it time's the fill..
Dec 11, 2009 | Washing Machines
The ice marker does not make ice. Have looked
If theres water in the line going to the fridge and the ice maker works , most of the times the water valve ( solenoid) that opens when the ice maker needs water , is leaking or doesn't work.
Aug 14, 2009 | Refrigerators
Ice maker grinding sound
I found I get a odd clicking noise whenever the icecubes freeze inside of the box in the top left. You'll see about 20 little fingers, arms, or whatever you want to call them that spit out the ice into the container...make sure those fingers/arms arent stuck from the ice.
Jun 11, 2008 | Maytag MSD2651 HE Side by Side...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
165 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
