Question about Epson Stylus Pro 11880
Epson 11880 maintenance request 4000
I have a 1 1/2yr old 11880. the display reads "maintenance request 4000" I have removed the right cover and inspected the capping station, the AID, and the print head. everything is very clean and functional, also no visible issues. what does this code mean?
SOURCE: How to remove print head of epson stylus photo r1800
Had the same problem - but the print head is actually easy to remove.
1) Remove ink cartridges
2) Remove 3 Phillips head screws at the bottom of the cartridge housing. (looking down from the printer front - top left, bottom left, top right).
3) There are 2 small plastic tabs on a plastic bracket that secure the flex cable on the right hand side of the cartridge housing. Gently release the tabs with a small flat head screw driver.
4) Lift the print head straight up (don't pull on the flex).
There may be a release for the flex to separate from the print head. But I did not see one. Instead I poured 1/4" of Windex in the bottom of a small plastic container and soaked my print head for about 15 minutes (occasionally agitating).
Then put back in reverse order - be sure to seat the flex in the guide (top-back-right) of the cartridge housing before screwing down. Then run a cleaning or two to flush the cleaning fluid out of the print head. (I have a waste ink tank installed so I am not worried about dumping excessive ink into the waste sponges).
The differences was remarkable - though there was still slight banding - maybe should have soaked longer (1 hr perhaps?) - I may repeat if it remains an issue.
Additionally there were large solid deposits on the left side of the print head which were responsible for scraping heavier weight photo paper. These dissolved in the Windex too.
Posted on Apr 07, 2009
efs_perpends
  • 1996 Answers
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
  • 684 Answers
SOURCE: Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Posted on May 27, 2009
SOURCE: maintenance request 0002
Epson
Maintenance request 0002What is this mean?
Posted on Jun 26, 2009
cns assoc
  • 677 Answers
SOURCE: How to clean my Epson RX595 Photo All In One
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Apr 05, 2010
Epson 11880 error code 1135
By doing a Bing search, it shows that error code means to replace print head. If you purchased it new, it shouldn't need a cleaning. You could try removing the print cartridge(s), then put them back in, making sure they are seated correctly, then restart the printer.
May 22, 2017 | Epson Office Equipment & Supplies
Epson stylus pro 11880 service call error 1136
this means the print head is locked.
Soln
Remove the metal plate on the left side of the print head to release the print head.
If it persists
Turn the printer off, leave it for a while, and then turn the printer on again. If this message appears on the LCD again, note the code and then contact Epson.
Jun 28, 2011 | Office Equipment & Supplies
Error code 0001002D is displayed and can not clear
Thank you for the inquiry.
This usually is a Epson Large Format printer error. You will need to replace parts to clear.
blank.gif headerline.jpg header.jpg epson_loyality.gif blank.gif menu_background_l.gif home_off.gifseparator.gifcoveragearea_off.gifseparator.gifservices_off.gifseparator.gifprinters_off.gifseparator.giftechnical_off.gifseparator.gifsearch_off.gifseparator.gifenquiries_off.gifseparator_r.gif menu_background_r.gif blank.gif 0001002D Cleaning unit EOL
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the check engine light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 0001002D will appear on your control panel LCD which is informing you that a maintenance procedure is due to be performed. This will normally involve replacing the parts which keep the print head clean, hence the error "cleaning unit END OF LIFE" and the waste pads. This procedure can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
worn_flushing_box.jpg worn_cap_assembly.jpg Worn flushing box Worn cap assembly worn_head_wiper.jpg worn_carriage_waste_pad.jpg Worn head wiper Worn carriage waste pad
Jun 03, 2011 | Office Equipment & Supplies
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Need manual and adjustment programme for epson 11880
My Epson Stylus Pro 11880 color ink-jet printer work fine but my problem is they can't print more than 7ft long & suddenly it's stop printing.
Jan 16, 2010 | Epson Stylus Pro 11880 InkJet Plotter...
Epson
May 19, 2009 | Epson Stylus Pro 7800 InkJet Printer
00010020 error
try this may be it helps you --
00010020 CSIC read / write --
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the spanner light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 00010020 will appear on your control panel LCD which is informing you that there is a problem communicating with an ink cartridge. This can be caused by a faulty ink cartridge chip or bent pins. This problem can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
Mar 09, 2009 | Epson Stylus Pro 9600 InkJet Printer
000100200 error
Remove the printer in printers and faxes and reinstall it with your original install cd
Nov 01, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Pro 11880 Logo
759 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
