Question about Electrolux Washing Machines
Ewf 1220 door says its not closed; but I think it is; what can it be?
  • Official Brand Answer
  • 4,342 Answers
Good Morning Jaap,
I see that you're having trouble with your Electrolux washer stating the door is not closed. There can be a couple of things to check with this. First check to make sure no clothing is in between the door and the drum. If nothing is obstructing the door then it might be a sensor. I would suggest contacting either the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Posted on Mar 27, 2014
How do I replace the door handle on a electrolux front loader ewf 1074 washing machine
hi
you need to take the door apart to be able to replace the handle
is a easy job but remember the order you take it apart to be able to put it back on
Apr 23, 2015 | Electrolux Washing Machines
How do you loosen the rubber ring around the fornt loader EWF 1074
If Its The One I An Thinking Of It Is a Spring Wrapped Around The Rubber And Is Fairly Tight ,You Can See The Spring If You Take The Top Off Of The Machine,You Have To Pull The Rubber Off If It Has This Type ,Some Have A Wire Clamp On The Inside Of The Machine Which Has A Screw To Be Loosened To Remove The Rubber
Mar 20, 2013 | Washing Machines
Electrolux ewf 1090 , door lock fried, replaced PCB and door lock , not going
Hello - From what you have described it sounds like the washer could possibly have a communication problem with the control board not responding. Since you have already replaced the door lock, I would strongly suggest contacting a professional to accurately diagnose the unit.
Sep 28, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Difference between hp printer1200 and hp printer 1220
the only difference it that hp-1220 is with the scanner attached and 1200 is without the scanner.
On the picture posted with the question is HP-1220, remove the scanner and it's talked about HP-1200
Cheers and visit us on //dentaltourusm.rs
Dental practice Mr dr Mirela Cvjetkovic Belgrade Serbia
Mar 28, 2012 | HP LaserJet 1220 Printer
My electrolux ewf 1030 get err 44 help me pls ?
E44 - It means "Door closure sensing circuit faulty".
Replace the circuit board and restart the diagnostic cycle to check further alarm condition.
When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5 on door interlock device, no.3 on electrical diagram) is powered by the triac (DOOR TY) on the PCB: after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed). The door interlock prevents aperture of the door while the appliance is in operation.
Microprocessor recognize closure position by sensing circuit connected to J2-1 on electronic board.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
electrolux-ewf-1030-get-qdylxco5jx0zjejqiwkxkzw5-1-0.jpg Dado
Aug 12, 2011 | Electrolux EW1200i Front Load Washer /...
Electrolux ewf 1029. What's wrong with it?
Something not working? Problems which you can resolve yourself, before calling the After Sales Service.
During machine operation it is possible that the end light
4 flashes= the door has not been closed
2 flashes= the machine does not empty
1 flash= the machine does not fill.
Once the problem has been eliminated, press the START/PAUSE button. In the case that the blown fuses due to consumption exceeding 10 amps and also have problems with the front cover microswiche which is not activating when you close the door. You should check the condition of the engine and change the microswiche of the door. Remove any objects from the pump impeller by rotating it.
Jul 28, 2011 | Washing Machines
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
