Question about Altec Lansing VS4121 Speaker
Constant static sound
My Altec Lansing VS4121 right speaker is emitting a constant static sound. I've tried unplugging the aux cord and left channel, but that doesn't fix anything. Any other solutions?
  • 205 Answers
SOURCE: Altec Lansing VS4121 no sound
If removing and reinstalling the driver fixed your problem then there was nothing wrong with the speakes. There was probably a problem with your soundcard drivers.
That being said, you should double check that you speakers are plugged in to the right sound board connector and the power supply is plugged into the wall outlet.
Does you computer have a headphone jack? If it does, you might try plugging a headset into it to see if you can hear sound there. If you do then you'll know the soundboard is working properly and maybe the speakers really are part of the problem. CD/DVD drives usually have a headset jack, but this will only work if a cable was run inside the computer from the CD/DVD drive to either the soundboard or motherboard.
What kind of computer do you have? Do you know if you have on board sound or a seperate sound board?
Posted on Nov 19, 2007
  • 238 Answers
SOURCE: altec lansing vs4121
u dont need any driver to play the speakers, yes the sound card does, take down ur sound card modle no. and try looking in www.driversguide.com let me know.
Posted on Feb 14, 2008
SOURCE: No Power (LED off) in the Altec Lansing VS4121
There is a fuse on the power supply board which is held in place with 4 screws. Yiu will have to unplug the sub-woofer connector to remove it.
Posted on Apr 15, 2008
  • 11 Answers
SOURCE: Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Posted on Sep 17, 2008
SOURCE: my speaker altec lansing vs4121 is just humming
Check the audio amplifiers Ic´s maybe are burned
Posted on Aug 10, 2009
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Altec lansing vs4121 speaker boom sound
you may have blown out the speaker or there is a miscommunication between the laptop and the woofer
Jun 15, 2012 | Altec Lansing VS4121 Speaker
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
My right speaker altec lansing vs4121 no sound only power
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps
Jul 01, 2011 | Altec Lansing VS4121 Computer Speakers
My altec lansing vs4121 speaker have to much bass with several mp3 files, waht ca i do
If it's only certain MP3 files you might want to identify WHY those files have too much bass. THAT would have happened when they were created. It's not a speaker's fault how the music sounds. Then there's your PC or whatever other device it passes through. Lots of opportunities for MALadjusted sound. GIGO.
Apr 03, 2011 | Altec Lansing VS4121 2.1 Channel Powered...
My Altec Lansing VS4121 is having a sound as if it is grounded or something. First I thought it was just a wire connecting to my pc but it isn't. I tried to unplugged it to my pc but still producing the...
Hello Adrenalize, hi, you may be right, but also check other ICs as well, the humming sound can be caused by the amplifier or its preamp section, this is where the 1036 (this is a dc operated tone control) is located. But before replacing the 1036, try first replacing the POWER AMP IC. (my experiences with those humming sounds usually are caused by IC amplifiers and op-amp ICs.)
Dec 05, 2010 | Altec Lansing VS4121 Speaker
Static but no music from the satelite trebble speaker
Try to reconnect all the wires, the problem seems to be with connection. Instead of spending lot of money on speakers, you can buy just the wires, they are pretty cheap. Hope this helps.
Jul 25, 2009 | Altec Lansing VS4121 Computer Speakers
Regards, Andrew
Sep 17, 2008 | Altec Lansing VS4121 Speaker
Vs4121 altec lansing left speaker wire ripped.
Black should be ground and red is usually the actual audio cable. If you connect them wrong the should not short. They will just sound weird until you connect them properly.
Hope this Helps
Thanks for reading!
May 02, 2008 | Altec Lansing VS4121 Computer Speakers
No sound from the right speaker
Check the speaker if its okay, disconnect the left side one and connect the right side one and play. If it does not then the speaker is bad.
Jan 11, 2008 | Altec Lansing VS4121 Speaker
Altec Lansing VS4121 Speaker Logo
109 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
