Question about Brother MFC-440CN InkJet Printer
Ink pad purge
How to clean
  • Brother Master
  • 783 Answers
HI Darren,
I have sent you a article please check Step-by-step instructions HERE on page 5-4.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us ForEpson Printer Support
Posted on Mar 27, 2014
3 times reset purge counter always see error message ink box full what the solution?
There is an absorbent pad under the print head when it is parked. When you clean the heads it catches the ink. It's time to clean the pad.
Mar 16, 2016 | Brother DCP Office Equipment & Supplies
Unable init. 50 on my Brother DCP-J315w ...what should i do
Any failure to initialise, print, clean error report usually indicates the waste ink chamber is full and the purge count has maxed out. You can remove the waste ink chamber, clean and replace the pads and refit it but seriously time consuming and messy. You should try the purge count reset first (do google search) eg this one
http://ref.topictimes.com/videos/tech/how-to-reset-purge-counter-on-brother-dcp-j315w-printer-full-1NzJwuCpVOc.html
If that works, you can keep using it but should clean the waste chamber. Or save the hassle and just buy a new machine :-)
Jan 05, 2015 | Brother DCP-J315W Inkjet Multifunction...
Error code 5C00 on Mp 500 please help with fix
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30.
Dec 01, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error 5C00 canon 4700
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. Open the cover and when the head comes to the center, pull the power cord. Once that power is off you can now move the carriage to the far left so it is out of the way. Now use a paper towel and gently blot all the excess ink off of the ink Pads and press them down. If the Wiper blade is extended, clean it and it should snap back in position. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30.
Nov 26, 2010 | Canon PIXMA MP510 All-In-One InkJet...
5c00 error
Error 5C00 is Purge Cam Sensor error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need repairing.
Nov 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Error 6A00 mp500 canon
6A00 is a purge unit error, the station that cleans the printhead on the right hand side. Usually the wiper is jammed into the cleaning pads because of ink buildup. Water on a Q-tip can help clean that area or you may need a new purge assembly about $29.00
Oct 15, 2009 | Canon Pixma MP500 All-In-One InkJet...
Most of Group 1inks,(except red) won't print
Over on the right is not waste ink pads, waste ink is under the print engine covering the whole bottom of the printer. On the right is the purge assembly and there is ink on the filters on top and on the squeegee that wipes the printhead. You may need a new purge assembly, or just re attach a hose in the purge unit that may have come off. That printer is well worth the repair...
Sep 10, 2009 | Canon i9900 InkJet Photo Printer
Canon image class mf6530 blank copies
It sounds like a complete print head failure.
try cleaning the printhead with distilled water.re-install the printhead.it most probably fixes you r problem.
if it still doesnt work,
I think you have a clogged or broken purge unit. This is a key component in the printer. It's job is to **** ink out of ink carts down into the printhead and Prime the head so it is ready to print.. No suction, no ink, no print.
Try cleaning both of the ink pads by saturating them with warm/hot water, then close the cover and power it off. Wait 1 minute and turn it back on and repeat the hot water until you can see the pads coming almost white. Now run a Deep cleaning cycle and nothing else. Then open the covers and examine the ink pads. If you don't see fresh ink (Black or colors) then the purge unit did not **** any ink.
if all of this dont work
you ought to call the Canon customer care.
Thankyou
Aug 07, 2009 | Canon imageCLASS MF6530 All-In-One...
Canon PIXMA iP4200 - not printing in colours
hi i am a Canon certified tech for this machine.the orignal problem you had most likely was not your printhead but since you washed it most likely it is ruined. the problem most likely is the purge unit. the purge unit is the unit to the far right of the machine. this unit cleans and purges ink from the ink tanks to the printhead. to do this it uses 2 pads one for black and one for color. these pads can be flushed with water to soften up any ink. i would also replace the printhead which can be ordered by calling 1-800-OK-CANON or by going to their website. one other tip, refilled ink cartridges cause more clogging of printheads and purge unit then OEM ink. this is because the ink is thicker then the OEM ink. hope this helps to clairify.
Jan 02, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Brother MFC-440CN InkJet Printer Logo
26 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
