Question about LG WM0642HW 4.0 cu. ft. Front Load Washer FACTORY REFURBISHED FOR USA
Water does not drain
During cycle water does not drain, but continues to fill until water gets above door and forces bottom of door out and water leaks out. No error codes appear. Have replaced drain pump motor and problem persists.
    Welcome Back:
    Visited the website for 2 consecutive days.
Is the drain line clear? Also sounds like time on water inlet is running to long. Front loaders don't use that much water.
Posted on Mar 22, 2014
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Bosch 500 series wfmc3301 bosch washer does not stop running the water during a cycle . even will do it with the spin and drain cycle. Even attempting to turn the washer off it will still run and then once...
You have a bad water supply valve which is struck in the on position-this valve is mounted inside the machine right where you attach the supply hoses-cheers Denny
Oct 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Flashing but nothing happening
A-- If you hear the water filling for 3 minutes before the lights flash, 2 things could be happening:
a.1) water never reached the proper fill/run level so the computer prevents the heater from starting and alerts the user. There should be a code list in the troubleshooting section of the user manual describing the blinking lights and what they mean.
Solution- verify by sound if water flows at the same rate as the sink tap, if not then shut off the water and check the inside the connection hose for debris against the screen inside the hose end or insid ethe machine end where there is a intake valve. The debris keeps sediment out so it works but there's no auto cleaner for the screen.
a.2) Otherwise the heater itself is faulty meaning it does not conduct an electrical path or maybe overheating (could be dry) and the computer senses the wrong temperature either too high or too low.
Solution- A service call to determine the reason why; heater continuity, water valve, heater relay, hi-temp fuse, etc.
B-- Now, if you do NOT hear water filling for those first 3 minutes, 3 things could be happening;
b.1) House water supply is turned off.
b.2) hose is clogged (see solution a.1 above)
b.3) Drain pump inside dishwasher was clogged during the last run and old water didn't drain out (maybe some water is evident in the tub bottom).
Solution- Most dishwashers start each wash cycle with 30 second drain pump running to make sure the tub is completely emptied so the next fill cycle can't overfill. This ensures that if the user finds a 3 liter pot that flipped over during the last wash and if they dump that full pot of water into the unit to make it lighter, that the water will get drained before the new water enters the tub.
If the drain pump is clogged reset the power and restart the wash cycle. Note how much water is in the tub and see if it goes down any during those 30 seconds by opening the door afterwards. Find the clog either a bone or plastic bag or some small pice of a childs toy is stuck in the drain pump or the other end is clogged maybe by grease or bones if you have a sink disposal unit. The things they grind up drop into the drain 1" inch above the hole for the dishwasher drain tube.
NOTE: There is also an overfill [float] switch if the water inlet valve gets stuck open and the water keeps filling, the drain pump is switched on until someone comes and shuts off the water supply. When the tub drains the float drops and the drainpump stops. This will also make lights blink so check the user manual for codes or call the factory service reps [1-877-337-3639].
Either way, there should be instructions to reset the machine for restart. If it doesn't reset you need someone to fix the control that tripped the unit, maybe a safety fuse or a broken piece of the puzzle.
Aug 17, 2013 | Haier DW12-PFE2 24 in. Dishwasher
Hi I have a problem with my Bosch SHU43CO6UC/22 dishwasher. using "power scrub plus" and "regular" cycles it will continue to fill and overflow the door, after the cycle has run even...
The bosch dishwashers use a fill valve that is attatched to the inlet hose. yours is stuck in the open position. this usually happens when you have hard water, as the minerals build up on the sealing surface of the water valve. there is no easy fix. the fill hose will have to be replaced. It requires removing the machine, removing the bottom pan, and changing the hose connections.
the valve uses water pressure to stay closed. if the water pressure is very low coming in, it may not be enough to close the valve. there is a filter screen between the fill hose, and where it connects to your water valve. try cleaning the filter out and see if that makes a difference. If not, you will have to get the hose changed.
Nov 19, 2010 | Dishwashers
Washer drains at it fills up, so water level never gets to where it needs to be. This is in all cycles. Machine never get to a point where it starts running.
Your drain hose needs to have the "curved" part above the level of the basket top. Otherwise, water will continually run out (usually onto the floor).
Some models have a stand alone water pump that is turned on to drain the washer. The timer (during drain, spin, etc cycles) turns this pump on and off. If your hose is inserted into the stand pipe as it should be, then the water pump being turned on is likely the problem.
Since you aren't mentioning that water is all over your floor, I think that a loose / torn hose can be ruled out as well. You need another timer switch assembly.
Jun 28, 2010 | Maytag HAV2557 Top Load Washer
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer is not filling during rinse cycle.
Sounds like the water is being siphoned out by the drain hose. Check to see if the drain hose rises above the top of the tub.
Oct 29, 2007 | Maytag Performa PAV2200
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
LG WM0642HW 4.0 cu. ft. Front Load Washer FACTORY REFURBISHED FOR USA Logo
125 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
