Question about One For All URC-3445 Remote Control
Upc flashes four times
When i hit the tv button the upc button flashes four times
    Top Expert:
  • One For All Master
  • 74,459 Answers
Check the remote control for its infrared emission. It sounds like the infrared emitting LED at the front of the remote control is not functioning well. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
One among the posts by this site, have details about how to check a remote control. If you wish to get sett-up codes and other details, check this site. http://electrohelponline.blogspot.com/
Posted on Mar 21, 2014
Emersin tv
which Dish Network system do u have. If it is the Hopper they program a little easier that the others. but if you have anything other than the hopper u do this. #1 turn onTV,#1 take Dish Remote,#3 press and hold down the TV button on top of the remote, hold it till all four lights light up.#4 press the small red TV button,# now press and click the channel Up or Down , do this one click at a time , (do not just press and hold ) this may take 200 clicks so don't give up. #5 when the TV goes off u quickly press the #(pound button) located on the bottom right of the remote. the TV button on top should flash 3 times. Now try to turn the TV back on.Ok now if you are clicking the channel button too fast and the TV turns off and u pass it up no sweat,,just hit the # button anyway.. and start from the beginning again, but this time use the OTHER channel button the TV should turn off within a couple of clicks. (that saves you from having to hit the button another 100 tries.. ha good luck
Sep 29, 2014 | Televison & Video
Sony tv won't turn on... When I hit the power it kicks in for seconds. the green light flashes four time then red flashes three times.
Tries unplug,replug tv back in an hour later,let the tv reset itself back to factory setting.The tv should work now.Not than the power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 15, 2010 | Sony Televison & Video
I have a kv-32ls60u Sony TV. It blinks 5 times
The most common failures are the flyback transformer assembly and sometimes some of its support components, and or there is the possibility of a short in the CRT electron gun. In either case, the power supply is going in to protect mode, and the uPC is sending this flashing error code to the front LED.
I have no idea if the flyback transformer assembly is still available, but I am very sure the CRT is no longer available. In any case you will find the cost of servicing your set to be expensive for its age. The last time I checked, the cost of the CRT exceeded the replacement cost of the set.
Jerry G.
Nov 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Key is flashing and the buttons are not working
Hit enter four times, which will put 0000 above the flashing key. This is the defalt code. If you have changed the code to your own, then enter your code with the up/dn buttons, then hit enter.
I have four of these cameras. They are sensitive.
Aug 13, 2009 | Bushnell Trail Sentry 11-9200 Digital...
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Volume control stuck on max AKAI CT2716
It seems that you most likely allowed some liquid to flow down to the circuit board. I can probably gaurantee that there is damage done to the control circuits for the uPC or the uPC itself.
You will have to give the set out for service. You may be lucky and it is only the control board including its electonics that has to be replaced. If the damage was done to the uPC or if there is a damaged buffer IC on the main circuit board between the uPC and the control panel this repair will be very costly compared to just replacing the control panel cirucuit board.
When cleaning a TV screen use a very soft lint free tissue paper. Use only some light spray of a very weak or diluted glass cleaner, or just water on to the tissue paper. Never put enough liquid that there is a possiblity of some of it dripping down in to the circuit board.
I personal use a light spray of water on a soft tissue. This is safe, and will not remove the optical coating on the screen surface.
Jerry G.
Jun 01, 2008 | Televison & Video
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
One For All URC-3445 Remote Control Logo
43 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
