Question about Garden
Keep the tractor from jumping out of gears.
PTO gears not holding, the tractor keep jumping out of gears
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
What is the brand and model of the tractor. Most of the time when a tractor pops out of gear it is due to weak springs or a worn detent plunger on the shifter. You may have to pull the top transmission cover to inspect but I would probably have a new spring and detent ready to go in. How old is the tractor?
Posted on May 08, 2014
panilling9
  • 284 Answers
SOURCE: craftsman model 917.272950 lawn tractor won't start
OPERATOR PRESENCE SYSTEM
Be sure operator presence and interlock
systems are working properly, If your
tractor does not function as described,
repair the problem immediately.
• The engine should not start unless the
clutch/brake pedal is fully depressed
and attachement clutch control is in the
disengaged position.
• When the engine is running, any
attempt by the operator to leave the
seat without first setting the parking
brake should shut off the engine.
• When the engine is running and the
attachment clutch is engaged, any
seat should shut off the engine.
• The attachment clutch should never
operate unless the operator is in the
seat.
Check your seat switch and clutch switch wires be sure that the connection to each switch is making contact and the mechanism that activates the switch is actually activateing them in other words be sure the clutch is pushing the switch in and your seat switch is occupied and be sure all grounding wires a intack
especially from your battery negative to the frame.You also could have a neutral safety switch which requires your transmission to be in neural.
try these things and let us know how we can further help from more of your input.
Posted on Jun 08, 2009
  • 95 Answers
SOURCE: Craftsman 26hp Garden Tractor PTO not working
If you changed the belt make sure it did not interfere with the wire that runs from the pto clutch, sometimes that belt can rub on the wire and wear through it,also if you had the clutch off make sure you aligned the steel retainer bolt that sets in the alignment hole on the pto clutch,this keeps the clutch from spring when disengaged if you don't get that pin through the hole in clutch it can push on the clutch and bind it.Also it may be possible to plug that pto switch in backwards.Also if you jumped the fuse out it may now have burnt the switch or wiring somewhere.
Posted on Jul 30, 2009
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
d_hubbs
  • 270 Answers
SOURCE: I have a 2510 John
Hi, I'm David .Hope i can give you some help.
First of all I beleive if you Make Sure you Don't Hahave the Clutches Backwards,Its Easy to do this.To line them Up your going to need a Helper,Trying this by your self will were you out.
Check to make sure The Splines are the Same as the Old Clutches.Includind the amount of Teeth in Each Clutch Have Got to be the Same.
Second make sure you have Plenty of Slack in your Clutch Adjustments.Remember you just removed a Work set of Clutches.So you'll need to Back off The Clutch Adjustments.
To give you plenty of Slack.You might also want to See if your Dealer Has a Pilot Tool or Clutch Alingment Tool to Help you .
Sir I hope i've Helped you.
Please let me Know by Voting on The Quality of my Solutiuons. Thank You:
Posted on Sep 23, 2010
dcurryn601
  • 60 Answers
SOURCE: Have a Yamaha YT3600 lawn
the starter puts out the amps to charge the battery, you have do an amperage check to find out what its puting
any good parts store will set you up with an inexpensive tester
Posted on Jul 23, 2011
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
How do I replace the electric pto clutch on a Troy bilt RZT 50 ?
b2b3a5a6-0c1f-4aa7-a9a9-2c36ba7a3894.gifremove center bolt holding the clutch one and watch for a spacer to fall. when installing it theres an ear that has to line up in a notch on outside of clutch to keep it from turning
Sep 14, 2014 | Garden
Drive belt on deck keeps jumping off
The belt tentioner is loose.
Jun 22, 2013 | Craftsman Garden
I need to repair the steering on a Cub Cadet LT 1045 ANY HELP?
there is a plastic coupler the holds the shft to the gear they wear and don't hold the shaft tight to the gear and they jump
Jul 31, 2012 | Cub Cadet Garden
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
I have an old 4020 and the PTO will not stop when the PTO handle is in the off position. Can you tell me what is likely wrong and is it a major fix?
The internal brake has gone bad... and yes it is a major fix, because the tractor will have to be split to get to it...
You probably can stop it with a gloved hand by grabbing a hold of it...then you can quickly get a PTO shaft against it and get it hooked up...any drag from a machine should be enough to keep it stopped...
If it is pulling harder then that then you have even bigger problems, as the throwout is bad inside and the PTO is constantly engaged...
heatman101
Jul 30, 2011 | John Deere 4020 Gas & Diesel Tractor...
John Deere sx85-engine stops with any gear selection
Park brake switch ,pto switch and seat switch will all shut down the machine,pto and park will also keep it from starting,so start at the seat.
Nov 24, 2009 | Garden
Ford 8n tractor.when i put a load on the pto , it pops off
You should repair that PTO system before it gets worse.
Get a repair manual and fix it.
I can't explain the repair here.
Keep in mind.......everything on your tractor is easy to fix.
Jul 21, 2009 | Ford 8N Tractor
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
