Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
My 2 stroke outboard motor engine sometimes just makes a lot of noise whilst running but it does not propel the boat forward what is the problem here
The outboard runs well and everything seems to be in order only when sometimes it runs then I just get an increase noise from the outboard motor but the boat is not moving at all why is this?
    Problem Solver:
  • 8 Answers
Rubber hub in the prop might be spun and slipping . If it doesn't have a hub, the shear/drive pin may be sheared off especially if the prop has hit a rock or log.
Posted on Jan 09, 2016
    Sergeant:
  • 456 Answers
Either it's not going into gear properly or bush in propellor is faulty
Posted on Mar 22, 2014
  • 187 Answers
SOURCE: 4hp Force Outboard motor overheating
Its possible it sucked up weeds or a plastic bag it into the intake and dropped off when you shut it down.
Posted on May 13, 2009
  • 23 Answers
SOURCE: Yamaha 30 HP 3 cylinder 2 stroke
Did you change plugs? If you did chek the plug to see if piston has hit the end of plug. Do a compresion check Jim OMC retired Mech
Posted on Jul 07, 2009
  • 12 Answers
SOURCE: my yamaha outboard will not shut off?
Check that the ignition swith is grounded.
Posted on Oct 08, 2009
  • 677 Answers
SOURCE: 4 stroke 6hp mercury outboard -brand new first
????? Was the dealer using his fuel tank or yours.Might be a blockage or contaminate in the fuel tank.Hope this helps
Posted on Dec 03, 2009
  • 677 Answers
SOURCE: Gear shifter locked in forward gear
If the gear lever is loose,it's the gear connection rod that you disconnect to do a g/box drop.If its not loose, drop the g/box off the leg and the first thing you find might be the problem.A loose bolt,a jammed shifter.It will probably be a connection problem than a g/box problemHope this helps
Posted on Jun 24, 2010
2009 Mercury bigfoot 60 outboard will not go into gear? What could be the problem? Runs fine otherwise.
Good Morning Anna,
Start At The Control Box,
Safety
1.Disconnect The Battery
2.Remove The Kill-Switch Lanyard
3.Remove Engine Cowl
Whilst Someone is turning the propeller operate the control lever into forward gear.
Check- Does The Control Cable Move a Lever At The Motor Side
Yes/No
Move The Control Lever Into Neutral Does The Lever Move at The Motor Side Yes /No
If Your Answer Is No Then The Problem Lies With The Control Box And Cables.
If Yes Then The Problem Lies Between The Lever You See Moving In The Engine And The Internal Gear Selectors Inside The Gear Housing.
If You Are able To Open The Gearbox And You Require Further Assistance I Can Guide You Further.
Hope This Helps
Regards
Gordon
Jul 09, 2017 | Mercury Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
How to winterize 175 mariner outboard motor
Take a look at these instruction videos.
How to Winterize an Outboard boat, step by step guide in ...
9k=? 11:25 https://www.youtube.com/watch?v=x217iM77Qjc Oct 30, 2012 - Uploaded by Warren Hardy A detailed step by step guide to winterizing your outboard boat motor for ... most 2-stroke outboards ...
Winterizing Your Boat: Step 2 The Engine & Lower Unit ...
9k=? 10:01 https://www.youtube.com/watch?v=5kiOms2f4gg Oct 6, 2009 - Uploaded by West Marine How to Prepare Your Boat for Winter - Step 2 in the five step process on How to Winterize Your Boat: The ...
How to Winterize a Four Stroke Outboard Motor - YouTube
9k=? 2:44 https://www.youtube.com/watch?v=PRBnwYk8_Yk Nov 7, 2012 - Uploaded by boats.com Four stroke outboard motors are by far the most popular on the market. But there's a lot of confusion about ...
How to winterize your outboard
www.classicglastron.com/gl-outboard-winterizing.htm For smaller outboards, the simplest way to flush your outboard is by using a large ... water or purchase a set of "ear muffs" (available at your local marine dealer).
How to Winterize an Outboard Motor - Adventure
adventure.howstuffworks.com/outdoor.../how-to-maintain-a-boat4.htm ... the winter and prolong its. Learn how to properly winterize an outboard motor. ... Buy lubricant, oil, and fuel conditioner at a marine store. Time: about 2 hours.
Jan 09, 2016 | Boating
How do I winterized a 40hp evenrude 2stroke
There are videos all over YouTube that cover this subject quite nicely.
winterizing an outboard motor YouTube
Nov 15, 2014 | Boating
Water got into the engine oil of my 8 hp 4 stroke when on the boat only as troller
Water gets in your engine through the exhaust with the boat speed! Lift that engine when not in use!
Oct 16, 2014 | Mercury Marine 8hp & 9.9hp 4 Stroke...
I have a polar kraft outlander 186cc fishing boat and a Yamaha f90 four stroke outboard motor. Where do you hook up the steering hose from the boat to what part of the motor?
To The Hydraulic Cylinder Mounted At The front Of The Outboard,
If The Motor Is Not equiped With The Cylinder You Need To Purchase and Fit It to The outboard Engine
Hope This helps
Gordon
Jul 17, 2014 | Boating
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
Just bought a used boat, 1966 sportscraft with an evinrude 2 stroke motor, don't know how to test the motor without going into the water. don't know much about boats
Hi. If you just want to run the motor then you can do it in you driveway. Go to a sports store with boating equipment and ask for "Muffs" to run your boat motor out of water. You can see a pictures of outboard motor muffs on google images:
http://www.google.com/images?hl=en&source=imghp&q=muffs+for+outboard&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
Take the muffs and place them over the water intakes located above the propeller (look like vents on each side). Hook a garden hose up the muffs and start water flow. Make sure nothing is near the propeller. Make sure to pump the bulb in the fuel line to the motor until it stiffens. Crank the motor. When the motor starts, you should see water start to flow out of the back of the motor near the cover and out of the center of the propeller with the exhaust. You must keep water flow to the motor using the muffs while it is running or it will burn up.
Apr 27, 2010 | Boating
2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Oct 31, 2009 | Light Outboard Motor Boat Bass Fishing...
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
198 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
