Question about Porter Cable Air Tools & Compressors
Air compressor building good pressure but won't shut off
Clfcp 350. runs good, but will not shut off at any pressure?
  • 1388 Answers
SOURCE: WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Posted on Nov 27, 2008
  • 65 Answers
SOURCE: coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Posted on Dec 03, 2008
mrhappyface
  • 205 Answers
SOURCE: air compressor fills, but slows down as the pressure builds
sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
Posted on Mar 23, 2009
mrhappyface
  • 205 Answers
SOURCE: Mastercraft 2.0 hp air compressor will not build up over 25 psi
sounds like a bad or broken valves in the head. crankcase needs a vent which is sometimes a small hole drilled into the oil fill plug and will normally blow some air out the vent while it runs
lester482529
  • 226 Answers
SOURCE: no air pressure
TRY ADJISTING THE TANK PRESSURE KNOB WHILE RUNNING ,TURN TO THE RIGHT 1/4 TURN UNTILL YOU SEE NEEDLE MOVE .MOST TIMES FACTORY SETS AT 0,SO YOU NEED TO ADJUST IT .MY ADVICE IS NO MORE THAN 90-100 PSI TILL YOU KNOW WHAT YOUR RUNNING MORE OFTEN
Posted on May 27, 2009
We relocated our Sullair 3700 about 30m from air receiver, due to excess dust. Now the compressor never stops running, trips on high pressure yet the receiver is not achieving the pressure required
would say dust has done something to do with it
before you had time to move it
will need the compressor serviced
first ..in simple words
to replace the compressor pressure shut off /turn on valve
that should fix the pressure trip build up limit problem
and maybe a partial strip down to clean out the casing
if dust build up is noted
Oct 14, 2016 | Sullair 350 Air Compressor; Sullair...
My ingersoll rand compressor won't get up to set pressure
Hi bryon
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Apr 05, 2013 | Air Tools & Compressors
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
If correct then it will **** you hand against the intake.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
Pump is not shutting off, and pressure not building up
Hi Kendal
Bud
Nov 01, 2012 | Campbell Hausfeld 26 - Gallon Air...
Craftsman air compressor model 191.135131 wont build pressure
I can not find a Craftsman compressor with that model number anywhere so here are a couple things to look into. If the compressor fills to 70psi and keeps on running check the valve plate and piston/cylinder assemblies. Check that the valve reeds on the valve plate are not bent, broken or warped from heat. Then check that the wiper (oil less) or pistion rings (oil splash) are not damaged and that the cylinder wall is not scarred up. Any of these will let the compressor fill up to the point where the air pressure leaks past the valves or piston and won't fill any further. If the compressor fills to 70psi then shuts off the problem is in the pressure switch. Some have an adjustment screw or bolt to control when it turns on and shuts off. If you had a drop from 100 to 70 the springs may be weak or broke and you'll have to replace the switch.
May 22, 2012 | Craftsman Air Tools & Compressors
Takes long time to pump up, then have to shut it down, compressor acts like it wants to stop, but if I remove small line and let the air out of that side where the line connects, it will run fine but of...
Hi dmream55...
Sep 22, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
Air compressor fills, but slows down as the pressure builds
Mar 22, 2009 | Campbell Hausfeld Air Tools & Compressors
Air Tools & Compressors Logo
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
