Question about Garden
Zetor 3320 parts diagram
Need a diagram of the position of the PTO gear service manual
  • Garden Master
  • 2,478 Answers
Try GOGGLE it
Posted on Mar 21, 2014
Zetor tractor how to drive
Yes, the PTO drives the hydraulic pump.
Feb 24, 2015 | Garden
John Deere 3320 PTO will not engage. Has new
well you need to check
fuse
wiring
pto
safety system
Aug 30, 2014 | Garden
We had several, identical gearbox failures on several Merceds Benz 1823 trucks. Each time the PTO pump was ripped off and the bell housing destroyed whilst the vehicle was driven on a straight road. We...
There is a gear that is in constant mesh in the PTO with a gear in the cluster shaft of the gear box. Fitting a PTO is a critical operation as there are shims between the PTO flange and the gear box housing to ensure correct teeth clearance . IF this clearance is not enough then the gears bottom out and jam prevention proper lubrication and rotation. Also it is vital that the teeth pitch of the PTO gear matches the pitch of the gear box gear as this will cause the PTO to be pushed of the side of the box.
Feb 21, 2014 | Cars & Trucks
I have a 2011 cub cadet ltx1040 with 42 inch mower deck. replaced belt, pto cable and spindle brake pads. Belt is still loose when pto engaged and cannot find any adjustment to tighten belt. All parts...
If all the parts are correct then you need to check the belt routing diagram. Sometimes you can find it on the mower deck and in the owners manual. Look carefully at the spring locations on the deck to be sure there correct. George
Aug 31, 2013 | Garden
I have a zetor 8111 and the lift wont work and the pto fails under load
Motherboards do not have Power Take Off units. Try in a different section.
Mar 04, 2013 | Computers & Internet
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Oki 3320
There is no easy way. You need to adjust starting position for every form. There is fine feed function and Top Of Form setting procedure, so you can adjust the minimum space between top of porm and first printed string (user's guide explains in details how to do it). But after that you need to decide whether you manually set the start position by rotating the knob or play with your application to adjust margins etc.
Dec 24, 2008 | OKI MICROLINE 3320 Matrix Printer
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
