Question about LG RD-JT91 Multimedia Projector
Proyector lg rd-jt91 no enciende y parpadean todas las luces del panel de control
3 Suggested Answers
Marrie
  • 563 Answers
SOURCE: LG RD-JT91 PSU problem
Hi there
On the left hand side where all the inputs are located you will see a very small screw , that is most probably what's keeping you from opening it.
Also remember to take off the cover to the front and do this slowly because the translation board's lint is attached to the top cover. Once open you can just unhook it and then you'll be looking for the board with the AC inlet on it.
Posted on Apr 16, 2008
SOURCE: A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
Posted on Nov 26, 2011
How to reset error lights
The lights indicate that the child lock. press to turn it off while the two keys shown at the bottom of the control panel for this purpose. Deshacer cambios Tu contribuci?n se utilizar? para mejorar la calidad de la traducci?n y podr?a mostrarse a los usuarios de forma an?nima. Enviar Cerrar Gracias por tu env?o. Definiciones de Las luces indican que esta activado el bloqueo infantil. para desactivarlo oprima a la vez las dos teclas que se indican en la parte inferior del tablero de control para ese fin. abreviatura (in tables of sports results) games lost. sustantivo the twelfth letter of the alphabet. a shape like that of a capital L. "a four-story L-shaped building" the Roman numeral for 50. Avogadro's number. 2 definiciones m?s Sin?nimos de Las luces indican que esta activado el bloqueo infantil. para desactivarlo oprima a la vez las dos teclas que se indican en la parte inferior del tablero de control para ese fin. sustantivo
  • liter
  • fifty, 50
  • lambert
5 sin?nimos m?s Ejemplos de Las luces indican que esta activado el bloqueo infantil. para desactivarlo oprima a la vez las dos teclas que se indican en la parte inferior del tablero de control para ese fin. 3 ejemplos m?s Ver tambi?n l, L., L/C, B/L, L-bar Traducciones de Las luces indican que esta activado el bloqueo infantil. para desactivarlo oprima a la vez las dos teclas que se indican en la parte inferior del tablero de control para ese fin. sustantivo el pap? dad, daddy, papa, pop, pa, pappy
Oct 20, 2014 | Samsung Dishwashers
Mitsubishi el
buenas , verifica primero los fusibles que no esten fundidos, si los fusibles estan bien verifica entonces si tiene buena conexion de tierra (ground).
Dec 26, 2013 | Cars & Trucks
Porq no enciende pantalla del radio mitsubishi lancer 2009
donde va el relay que mencionas amigo? me paso el mismo problema
Jun 07, 2012 | Cars & Trucks
No me ensiende
Si te refieres a que el televisor no se enciende, entonces esta es la solución.
Hay una buena probabilidad de que no tienen condensadores electrolíticos, ya sea en la etapa de potencia o la sección del inversor o de ambos.
Todas las tapas en estas secciones que se ven abultados en la parte superior, o abultados / fugas en la necesidad de fondo para ser reemplazado.
Si repetidamente se enciende, con el tiempo probablemente se quedará, pero cada vez que lo apaga, la TV será más difícil y más difícil de poner en marcha hasta que un día simplemente no lo hará.
A veces hay que hacer lo contrario para poner en marcha y desconectar por 5 minutos, a continuación, intente.
Si usted no es experto tecnología, esta unidad tiene que ir a reparar.
Si usted es hábil con un soldador y puede identificar la fuente de alimentación y el inversor / sección de FM para las luces de fondo, un puñado de condensadores baratos probablemente le arreglamos bien desde arriba.
Coincidir con la capacitancia de los condensadores. Ir más tensión si se puede, y todavía tienen que encajen.
IE - no es una mala idea para reemplazar una tapa de 10V con 16V, pero no reemplazan una gorra de 680uF con un 500uF o 1000uF (a menos que sean positivas es sólo hacer la ondulación de filtrado).
Mar 02, 2011 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
Luego de un rato las luces delanteras
Existe ahi un problema de falso contacto; sugiero revisar toda la instalacion, incluyendo el switch de encendido de luces. El Jeep 1984-2001 XJ 1989 Cherokee (Comanche) podria ser de ayuda.
Exitos (recuerde calificar esta ayuda).
Mar 05, 2010 | 1992 Jeep Comanche
My engine light is on and took it to auto zone. Code came back as Air injection system failure. Should i be concerned
TENGO PROLEMAS CON LAS LUCES DE FRENOS , NO ENCIENDEN YA PROBE EL VOLTAGE DEL SWITH DEL PEDAL DEL FRENO, AL PUSHAR EL PEDAL SALE VOLTAGE PERO LA LUZ DE ATRAS NO ENCIENDE
Feb 15, 2010 | 2008 Chevrolet Impala
Parpadeo de luces frontales roja y azul
parece que un driver del Iomega ya no trabaja bien. luego no es facil de descubrir cual driver. puedes tratar de apagar en encender varias veces a ver si otra vez quiere jalar, y luego tienes que copiar rapidamente tus documentos, pues puede ser que despues un dia tu Iomega se apaga completamente
suerte y saludos de Bernardo de Holanda
Nov 17, 2009 | Iomega StorCenter Pro NAS 150d (33612) 500...
Jeep Liberty 2002 , se pagan de pronto luces y cepillos parabrisa
revise todas las conexiones a la bateria , los que van a la carroceria o negativos , todos con mucho detalle
Jun 17, 2017 | 2002 Jeep Liberty
Mi ordenador no levanta solamente reconoce el teclado o al menos eso creo yo porque parpadean las luces del teclado pero luego de ahi no tango inicio y ya resetees la cmos es una biostar ''M7VIG PRO-D''...
Necesita chequear 2 cosas.
La memoria, para ver si los modulos estan dañados, o la fuente de poder....a veces pierde la potencia necesaria para alimentar todos las piezas que tienes, a pesar que "vez luces"..y la potencia no es suficiente.
Jul 21, 2009 | Computers & Internet
LG RD-JT91 Multimedia Projector Logo
374 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
Jaime Hernandez
Lawrence Oravetz
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
