Question about ESA ET432E TV
Picture is 1" across screen
The sound n color is good the picture came on 1" across the screen you can't use the remote cause you can't see anything there are no adjustment button on back of tv
    Habit-Forming:
  • 128 Answers
The vertical deflection section has failed. It could be a myriad of different things and if you are not technically minded and have an oscilloscope then all you can really check is the integrity of the soldered joints, and capacitors on the circuit board. Chances are, because you have at least an inch of vertical deflection then the fault will be a capacitor that has gone out of specification, usually high. Check around the vertical section for capacitors that have the plastic wrap shrinking on them, or around heatsinks. This is usually a good place to start. Replace any suspect looking ones or remove from the board and test individually.There will not be any user friendly vertical adjustment control. Who knows you might get lucky! Good luck
Posted on Jul 31, 2014
Turned tv on a line came across tv about an inch wide of the picture the color n sound is good how do I widen picture picture
Vertical scan output section circuit fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 21, 2014 | ESA ET432E TV
Picture problems
Is it one color that has moved? Sounds like a convergence problem. Find a channel with a fixed picture, or if you have digital cable or satellite pull up a guide, something with a straight line across the screen. You will likely see one of the colors is bowed or or shifted. You may be able to adjust that with your remote under the "convergence" adjustments in the menu. If it will not adjust it will need work done to the convergence circuit. Not a DIY project.
May 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture. Red-blue stripe across screen
there is a computer chip that is now toast on your motherboard. I don't remember the name of it but same happened on my RCA. It is caused by over heating. Over heating is caused by lousy vent design. Its important to place TV on hard surface NOT CARPET. I learned the hard way. The chip that went out is a $15 - $20 part, but finding someone to put it in for cheap is like winning the lotto. hope this helps.
Jun 24, 2009 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
EMERSON EWL2005 20" LCD
Impacting the television can cause the video processor to come unmounted to the main board or the LCD panel inside to become disconnected. You need to take it in for repair.
May 24, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
ESA ET432E TV Logo
Top ESA Televison & Video Experts
Colin Stickland
Colin Stickland
matt martin
matt martin
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
