Question about Brother MFC-9840CDW Laser Printer
Check paper size every time a fax comes in, reload correct paper
    Problem Solver:
  • 6 Answers
After you tried all of the suggested "fixes", contact Brother to see if there's a download that might address this issue.
Posted on Mar 21, 2014
jmassengill
  • 345 Answers
SOURCE: paper feedin
The price of labor and repair parts could exceed the cost of a new printer in some cases. This most likely wouldn't be something you might be able to repair yourself. I would call the authorized repair center in your area and ask about a quote on what it might cost to repair this printer.
Posted on Nov 10, 2008
  • 65 Answers
SOURCE: MFC -9420 CN Printer/Fax Scanner
I've seen this before...
The machine is calling for legal sized paper and it thinks it has it in the paper tray. Check the back stop that is inside the paper tray. It should be a green guide that is closest to you if you pull the tray out. You may have to lift up a flap on the end. Make sure that the paper stop is on the correct paper size for what is in the tray. Hope this helps. Let me know if you need any more assistance.
If this helps you please rate it as Fixya!
Posted on Nov 25, 2008
SOURCE: My read out says check paper size, when i reload
Did you try clearing your remaining jobs? Fax, menu, arrow down to #2 (fax), menu, arrow down to #6 (remaing jobs)....
this helped me.
jb
Posted on Apr 29, 2010
aviral_srms
  • 1216 Answers
SOURCE: when recieving fax machine says
The message "Wrong Paper Size" will appear on your Brother machine's display if the paper you have loaded does not match the Paper Size setting programmed in your Brother machine or the driver settings, or if the paper is oriented incorrectly in the tray.
If the message "Wrong Paper Size" is appearing :
PROCEDURE ?: Print from the Windows® PC or Macintosh®
To resolve this issue complete the following steps:
  1. In order to clear the message from the LCD, you will need to empty the jobs from the print queue. Complete the following steps:
    For Windows® Users:
    1. Windows®2000 Users:
      Left click Start -> Settings -> Printers (and Faxes)
      Windows®XP Users:
      Left click Start -> (Settings) -> Control Panel -> Printers (and Faxes) or Printers and Other Hardware.
      Windows®Vista Users:
      Left click Start -> (Settings) -> Control Panel -> Hardware an Sound -> Printers (and Faxes).
    2. Right Click on the Brother driver and select Cancel All Documents(or Purge Print Documents). You may have to make several attempts to completely purge the print queue.
    For Macintosh® Users:
    1. Click the print icon in the Dock.
    2. Select the document and click delete. Repeat this process and delete all documents.
  2. Press Stop/Exit if your Brother machine still displays the error message.
  3. Verify the paper settings for your document:
    Depending on your application, the steps for setting the document's paper size will vary. From many applications, this setting can be accessed trough the File -> Page Setup -> Paper Size menu. Please refer to your software's documentation for instructions on how to adjust this setting.
  4. Make sure the correct size paper is inserted in the tray you are printing from, and the paper guides are adjusted to fit the paper length and width of the paper.
  5. When printing, you can often access the printer driver's properties.
    For Windows® Users:
    The steps for accessing these settings, differ depending on you're application. From many applications clicking Properties or Preferences within the print dialog box can access this setting.
    1. Select Print Settings in the Print dialog box.
    2. Within the printing preferences window or Print dialog box adjust the following settings:
      1. Media Type: Select the media type to print on. The machine changes the way it places dots depending on the selected media type. For the best print results, make sure to select the correct media type.
      2. Paper Size: This Printer Driver lets you select the size of paper and envelops and also allows user defined sizes of paper.
PROCEDURE ?: Print copies or faxes (only MFC users)
To clear the "Wrong Paper Size" message you must do one of the following:
Loading the paper into the tray correctly
Paper should be loaded in the paper trays in portrait orientation. Do NOT load paper in the paper trays in landscape orientation.
Regardless of the paper size you are using, you must always load the paper into the paper tray so that the two longer edges of the paper face the left and right sides of the paper tray and the two shorter edges of the paper face the front and back of the paper tray.
Thanks
Posted on Dec 15, 2010
  • 83 Answers
SOURCE: window says wrong paper size reload correct
its in setting on printer icon put it on full page.
Posted on Feb 26, 2011
Reload correct paper
your printer papper seting is change the correct size of your papper
Mar 21, 2014 | Samsung CLX-3175FW Multifunction Laser...
Nov 25, 2008 | Brother MFC-9420CN All-In-One Laser...
Paper Size
double check the menu section is it set for Letter?
check the tray do you have Letter paper in it, are the guides set correctly?
Aug 19, 2008 | Canon LaserClass 2060 Fax
Brother 4100 intellifax
Check the blue tab on the inside of paper tray and make sure it is on correct paper size.
Fax machine is very sensitive so try not to put too much paper in it.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Check paper reload paper
Remove the paper tray completely and make sure paper is not binding and lifting up OK.
Jun 30, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Reload paper error
Listen for the paper tray is popping up when you push it in.
Remove the paper tray completly and look for paper in the cavity.
Jun 24, 2008 | Brother MFC-8220 Fax
Problem with Brother MFC-9420CN
This happened on my MFC-9420CN. It turns out the there are blue tabs inside the paper tray that hold the paper in place. If the tabs are not touching the paper, you'll get this "Check Paper Size" error. The printer thinks that you have loaded a different paper tray.
Don P. Greensboro, NC
Nov 07, 2007 | Office Equipment & Supplies
Check paper size comes up all the time. Also pulls anywhere from 4 - 10 blank pages through at once.
dear sir pleaz select the correct paper size in the user data programing of your machine
Sep 10, 2007 | Canon FAXPHONE L80 Laser
Constant messages "Check Paper Size"
Try this first..... Some faxes can be configured for different paper sizes for timing of the preinting process. This would be either tabs on the back of the paper drawer of a soft setting found in the owners manual.
Apr 17, 2007 | Canon FAX-L350 Plain Paper Laser
Brother MFC-9840CDW Laser Printer Logo
22 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
