BOOTMGR IS MISSING
WHEN LAPTOP BOOTS UP THE WORDS ON THE SCREEN SAY BOOT MANAGER IS MISSING
  • 3,320 Answers
Reinstall your operating system
Posted on Mar 21, 2014
Dell inspiron mini screen says "bootmgr is missing
You need to reboot the computer using the disk you made from Windows Backup and Restore. Watch your boot screen and look for "boot opions or boot order (words to that effect).
If always super important to create a Windows Startup Disk/Repair disk as soon as you power on your computer and go through the initial setup.
The next most important task is to create recovery disks. The ultimate task for any laptop or desktop computer is to create a system image backup onto an External Hard Drive. Why? Whenever you get infected or experience a major problem you are copy the system image back to your main drive and everything is in the state it was when you made the backup.
Files should be backed up on regular basis and having an External Hard dDrive always plugged into a USB port makes this a very simple task.
Apr 15, 2013 | Computers & Internet
Missing boot manager and blue on everything
if you boot pressing F8 can you get to the repair option?
Nov 27, 2012 | Computers & Internet
BOOTMANAGER IS MISSING
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
The latest versions of Windows, including Vista and 7, use the Windows Boot Manager to read the boot configuration files and data in order to load your Windows Desktop.
If any of these files are corrupted or damaged, you will see a "BOOTMGR is missing" error. Fortunately, you can use a number of Windows tools to repair or replace the BOOTMGR or any related file that may be the cause of the problem.
Insert your Windows installation CD disk in your computer's CD drive and restart the computer.
Press "F8" repeatedly while the computer boots up.
This command enters the "Advance boot options" screen.
Select the "Repair my computer" option and then press "Enter."
The System Recovery Options screen opens.
Select the "Startup Repair" option at the top of the list and click "Next."
The utility will scan your system for the cause of the BOOTMGR problem and repair it.
Hope this helps
Oct 30, 2012 | Computers & Internet
Bootmanager missing
Hope this helps
Oct 30, 2012 | Microsoft Windows Vista Home Premium with...
PC will not boot, BOOTMGR is missing. What do I need to do?
I assume it's Windows 7.
Check that the BIOS is set to boot from CD/DVD as the first boot device and then put the Windows installation disk into the drive. If done correctly then the PC should boot from the CD/DVD and then just follow the on screen instructions (follow the instructions and select the repair option).
Jun 08, 2012 | Computers & Internet
My HP pavilion dv6000 gives the message BOOTMGR is missing...why?
Bootmgr is short form for Boot Manager and is the Windows Registry File that must be present to allow Windows to boot.
It is either corrupt or missing. In other words, you will not be able to boot without the use of your recovery disk, that you made when you first bought your laptop, or your Windows disk.
Insert either in your DVD drive and boot the laptop, you will be given the opportunity to recover your system or rebuild your system from there.
If you press F8 whilst and just before it boots, you may be lucky enough to catch the recovery disk on your hard drive partition.
Good luck and I hope it fixes your problem.
Nov 22, 2010 | HP Pavilion dv6000t Notebook
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Missing bootmgr
something has removed the bootmanager from your harddrive your going to need the windows cd, you can try useing the repair console to restore the bootloader, also you can try a repair install or a fresh windows install.
Mar 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
