Question about Microsoft Windows XP Professional
Precisionscan fix for Sorry, cannot find required Library, please reinstall application."
  • 4 Answers
Sounds like you have a problem with a DLL "Dynamic Link Library" for whatever program you're trying to use. Most likely it's been corrupted possibly by a virus or bad sector on hard drive or a file that mistakenly got deleted or any other number of things. I have had this problem before but only with the operating system (Win XP pro) never with another program. In my experience the only really good way to fix it is to re-install the program. Best of luck. Definitely run virus scan to check your files. Also you may want to try fixing in safe mode first if it's an op sys file that is corrupt or you can try system restore Found in start panel/accessories/system tools. If it's a program other than your operating sytem I would just uninstall it and then re-install it. Hope this helps. P.S. Microsoft will stop supporting Win XP next month (April 2014) no more updates etc. You might just want to upgrade to a newer version of windows.
Posted on Mar 22, 2014
Windows configures microsoft visual c++
Microsoft Visual C++ Redistributable Package contains library files required to run applications developed with Visual C++. fo more help regarding Uninstall and reinstall follow Uninstall or reinstall Microsoft Visual and need any guidance in any technical aspect follow Intuit Support Number .
Jan 31, 2014 | Intuit QuickBooks Computers & Internet
Adobe Acrobat 7.0 Pro Error
Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue. These products were released more than seven years ago, do not run on many modern operating systems, and are no longer supported.
Download the New Copy of Acrobat and activate it with the new serial Number .
Click this Link CS2 downloads
Apr 22, 2013 | Adobe Acrobat 7.0 Professional
An error has been detected with a required application library and the product cannot continue. Please reinstall the application.
Basically lot of people are getting errors with Acrobat 7 and older versions as Adobe has disabled the activation server for CS2 products, including Acrobat 7, because of a technical issue.
Go to the Click here for the Link to Download Acrobat
Download the New Copy of Acrobat and Activate it with the new Serial No, however you need to un install the old copy from your computer
Apr 16, 2013 | Adobe Acrobat 7.0 Professional
Scanner connected to computer by USB and power; but no light is coming up. The software says: can not initialize; scanner not found. Yesterday he worked; today not.
Hi ,
Make sure driver is correctly installed . If not , go to device manager and delete driver . Now disconnect scanner and go to Control pannel to delete HP precisionScan Pro .
Reboot .
Do not connect scanner . Re install PrecisionScan Pro . Reboot and wait for Windows to be settled .
Connect scanner and wait for confirmation of successfull installation of driver .
If you are under W7 , PrecisionScan Pro will no more run .
Please go here for fix : http://www.fixya.com/support/t6707657-need_driver_hp
Regards .
Oct 28, 2010 | HP Scanjet 4470c Flatbed Scanner
Thw itunes application could not be opened. a required itunes component is not installed. Please repair or reinstall quicktime. (-42404)
Was it working earlier? if so, first try repairing using the itunes setup and click repair, if not, you'll need to do a complete fresh installation which will delete all your settings and data saved with the previous settings. If you can at least back up the library, do so now and uninstall the program, and again reinstall it. I hope you have a copy of Itunes with you. If not, download it from here..
Apple's Itunes applications
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Computers & Internet
HP5300C Cannot Find Scanner message from PrecisionScan SW
Does it show up in your hardware profiles? What does it say on details when you right click the scanner? When you installed the driver, was it before your plugged in the USB? You may have to uninstall and reinstall it again, this time use the one from HP's website with any patch if applicable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&cc=us&dlc=en&product=58381&os=228&lang=en
If you have successfully used it in the past, follow the install prompts and restart.. instead of using the products software, use Windows included scanning program which is much better than the proprietary one designed by HP. As long as you have the proper driver installed your system will know how to apply it.
Feb 25, 2010 | HP ScanJet 5300C Flatbed Scanner
Ereader library won't open
Hi.
If you're using the Windows Operating System, the issue may be caused by the Data Execution Prevention feature in the Windows Operating System or if certain folders used by the Reader Library Software are corrupt. Please click on the below link and select the desired Operating System to get the troubleshooting steps.
If the issue persists, uninstall the Software and restart the Computer.
Next, disable all the active Software's (Firewall, Anti-virus, etc) in the Computer and reinstall the Software.
Also, please ensure to check the "Launch Software" at the end of the installation. This should resolve the issue.
If you're using the Macintosh Computer, uninstall the Software as per the below mentioned steps:
First, click "Go" and then click "Applications" in the Main menu.
Next, in the "Applications" folder, in the right pane, double-click on the "Utilities" folder.
Then, in the "Utilities" folder, double-click "Terminal".Now, in the "Terminal" text window, type "sudo /Library/ebookLibrary/uninstall-ReaderLibrary.sh". There is a required space between sudo and /.
Next, please press "ENTER" on the keyboard. A confirmation message will appear. Please enter your Password or leave blank if you do not have a user account password.
After the Password has been entered or left blank for no password, press ENTER. You will receive the message that the Reader Library Uninstall is finished.
Now, please click "Terminal" and then "Quit Terminal" to exit the Terminal application in the Menu.
Finally, close all other open windows.
Now, restart the Computer and reinstall it.
Note: Ensure that the Reader is not connected to the Computer while performing any of the above mentioned steps for Windows/Macintosh Computer.
Feb 25, 2010 | Sony Reader Touch PRS-600
Excel not working upon start up
Make sure that you have all the updates for Microsoft office by visiting Mocrosofts website and download the hotfixes.
If that doesn't work
Try uninstalling office and reinstalling to fix the problem.
Sep 16, 2009 | Microsoft Office Excel 2003 for PC
..."failed to start because smv.dll was not found"
I had the same problem. When uninstalling, check "yes" when it asks you if it should delete the library database file (it will say to check "no" if you plan to reinstall; ignore that). If that doesn't work, try downloading iriver plus 3 from the the international version of the iriver website: http://www.iriver.com/index.asp
Mar 22, 2009 | iRiver E10 Digital Media Player
Photoshop element 5.0 trial download error
Have you reinstalled the application has the trial ceased? I f ll of these are yes no one can help you but the sofware company ....uninstall the programme or buy the full version.
Sep 15, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
