Question about American DJ Fogstorm 1700hd Fog Machine W/ Remote System
American DJ Vaporizer Fog hog
Unit powers up, remote lights, but unit will not produce fog.
  • Soundz Good Dec 03, 2007
    same problem lights on no fog
  • zizi_13 Sep 27, 2008
    Same, lights and power, no fog... solutions, please?
Sounds like the pump either is not working or can't inject the fog fluid ( solution of distilled water & glycerin ). My unit clogged up, so I took it apart and cleaned out the lines. Be sure to run pure distilled water through unit, after each use.
Posted on Oct 01, 2008
  • John G
    John G May 18, 2014
    What I did was disconnected the tube that goes from pump to the heater and on the pump I just turned to loosen the piece where the tube was connected one full turn, then just replaced the tube back to the pump piece.
LOST THE REMOTE FOR THE 1700 FOG STORM.CAN YOU JUST REPLACE THE REMOTE ,WHAT DO I DO THANKS MARK..
You can do that or you can also use it manually by pressing the red button in the back to produce fog manually.
May 21, 2011 | American DJ Fogstorm 1700hd Fog Machine W/...
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
Just bought a referb fog storm 1700HD and it wont opperate. Powers up and after leaving it heat for 20 mins nothing happens when using the manual or remote fog button with or without controler plugged in.
The circuit breaker or the fuse are bad. Open up unit to diagnose each. If fuse is blown then you should be able to tell immediately .To test the circuit breaker you want to test the resistance with a proper measuring device.
Sep 25, 2010 | American DJ Fogstorm 1700hd Fog Machine W/...
Shoots out liquid instead of fog...
that thing(the heater) just doesn't work well,
bring it to someone to repair it
Apr 23, 2009 | American DJ Dyno-Fog-II Fog Machine W/...
Low fog output
I had the same problem with an American DJ, I removed the pump took it apart and cleaned it. It had a stuck valve in it. It now works fine.
Oct 27, 2007 | American DJ Dyno-Fog-II Fog Machine W/...
American DJ Fogstorm 1700hd Fog Machine W/ Remote System Logo
1,875 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
