Question about FREUER Faucets Countertop Sink Mount SoPump Dispenser Polished
Freuer faucet leaking
Faucet leaking above the sink
    Sergeant:
  • 268 Answers
Contact Freuer faucet and get free replacement parts. I was even sent complete unit that I had to install.
Posted on May 01, 2014
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: Fort® Single-control...
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray is hard to turn
I have Geyser Kitchen Bar Sink/ Spray Faucet and it leaks at the turning joint.
I have a Geyser GF8 that also leaks at the turning joint. Anyone know how to dissamble one of these faucets?
May 21, 2010 | Delta Faucet Company 4538 Lahara Two...
Grohe ladylux plus kitchen faucet leaks from multiple points along metal pull out hose attached to faucet head. Is this fixed by replacement of same hose? How do I replace the hose?
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Feb 23, 2010 | Grohe Plumbing
I have a kitchen sink faucet that is leaking water from the back part of the faucet. There is a hole there and the faucet leaks water, when the water is on. Why is it doing this?
If it is a rusted hole get new faucet, but on many faucets that is where the Sprayer connects. Check for loose Sprayer hose at faucet under the sink.
Sep 14, 2009 | Plumbing
Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Mar 24, 2009 | Delta Model 470: Signature Kitchen...
FREUER Faucets Countertop Sink Mount SoPump Dispenser Polished Logo
163 people viewed this question
Top FREUER Faucets Home Experts
Donni Steen
Tom Chichester
Are you a FREUER Faucets Home Expert? Answer questions, earn points and help others
