Question about Traulsen G20010 Commercial Refrigerator
How toset tempeture on the thermostat
Keeps freezing up products
Tempeture keeps dropping to 20 degrees randomly, Thermostat has been replaced twice. After thermostat has been replaced it runs 38 degrees for 2 weeks then freezes.
SOunds like you need to have it checked for a low charge as this unit is a cycle defrost and if low on freon this will happen. As the thermostat won't cycle at its not filling the evaporator enough to register. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 14, 2016 | True TDBD-96-3 Double Duty Deli Case 96"
Why hoover fridge not cooling or freezing?
is it warm or hot to touch? no sticking defrost timer? if not then check the cold control tempeture thermostat, the thermistors, and the door seals, lastly may have a coolant problem, do any of the back copper tubes to the compressor feel cold to the touch
Feb 20, 2015 | Hoover Refrigerators
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
I have a BJ505T-L the fridge and crisper are freezing up, is that a thermostat issue
would check the thermistors and the tempeture control thermostat
Feb 19, 2015 | Refrigerators
2007 pontiac torrent. Keeps over heating at idle but is fine when drive 50+ mph. My first thought is thermostat. Plenty of fluid in the cooling system. Any thoughts?
thermostat is a good place to start the other is make sure you cooling fans are coming on ,might be a fuse problem or a tempeture sensor that activate the fans , hope I got you on the right track .
Woody
Aug 28, 2014 | 2007 Pontiac Torrent
I change thermostat, water pump, housing coolant sensor, but yet when i start driving the tempeture goes up and down and the heat gets kind of cool not all
poor coolant flow water pump? air lock in system? bring to operating temp shut down than open air bleed screws.
Jan 02, 2014 | 1997 Pontiac Sunfire
Everything is freezing in our refrigerator even
Your thermostat has failed and requires replacement. If the fridge is very old you could use a mains interupter device that has a temperature sensor that is placed in the fridge. There are several hobby kits for such devices usually used for converting old fridges for wine storage.
Sep 29, 2009 | Frigidaire Refrigerators
Freezing at any tempeture
I ordered a new thermostat (about $40 with shipping) & installed it. It's pretty easy to replace. The fridge has been working fine since.
Jan 14, 2009 | Sanyo SR-4910M Compact Refrigerator
GE GSS25PGMCC refrigerator freezing food
hello I think that this is what you are looking for . Hope it helps you out with your problem.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60218.pdf
Thank You for using FixYa
Dec 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer keeps freezing
you have a defrost problem pull the bottom kickplanel and look on the toe plate for a little piece of paper stuffed in there which will give you instructions for checking the defrost system if not reply to me ill se if i can find one for you
May 10, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Traulsen G20010 Commercial Refrigerator Logo
49 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
