Question about Hotpoint Dishwashers
Dirty glasses dishwasher
Hotpoint Ultima: After every wash my glasses have food residue on them. I have tried different temperatures , cleaning the DW including filters, self aid rinse and DW cleaner. I always use finish (as recommended) and salt and ruse aid. I am at a loss! Please help!
    Problem Solver:
  • 10 Answers
1st thing is make sure the dishwasher is heating up the water.
if it is heating... you spray arms may be blocked up with food particals.
Posted on Mar 24, 2014
SOURCE: Bosch SHX46A dishwasher
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Posted on Dec 02, 2007
  • 677 Answers
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Posted on Apr 10, 2008
SOURCE: Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Posted on Sep 02, 2009
  • 901 Answers
SOURCE: Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
Posted on May 21, 2010
  • 24 Answers
SOURCE: WONT WASH CLEAN ALWAYS RESIDUE LIKE
use CLR to remove any build up and then use LEMI-SHINE (walmart in dishsoap aisle) for the cleaning of your dishes. Works great for me as i have the worst well water on the planet.
Posted on Aug 11, 2010
I have a Hotpoint WMD 960 Ultima. When I remove the washing after a cycle, the clothes are covered in dirty marks. can you tell me if this is something you can advise me about?
Look within the drum and observe if there is any dirt on it. Also check the quality of water. Check if there is any dirt /grease from the drum bearings due to failure of the bearings/seals.
Finally have the machine cleaned using good detergent cleaner , please check the link below for some tips:
http://www.espares.co.uk/parts/cleaning-products/dishwasher-cleaning/p/1423
Jul 09, 2011 | Hotpoint Ultima WF860 Front Load Washer
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
Oct 30, 2010 | Kenmore 13863 Stainless Steel Dishwasher
Dishes are not clean and white residue is left on dishes
clean the filters or get new ones.make sure your water in is connected to the hot water not cold.Also put new rubber O rings on the spinning arm water sockets.
Jul 20, 2010 | Maytag MDB5100A Dishwasher
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Says model # shu9915 not cleaning well .leaving residue on glasses almost easier to wash by hand and some food stuck on plates etc. and soap tablets not dissolving completely
heatman101
Feb 14, 2010 | Bosch SHU9950 Dishwasher
The dishwasher doesn't clean properly
Lots of possibilities...
1. the sprayer arm might be sticking and not moving, or moving very little. Check to see if you can spin it by hand. Listen when the machine is running and you should hear the sound of the spray changing as it rotates. Check for items that might be jamming the arm like silverware, cups, jar labels, etc.
2. the little holes in the sprayer arms could be clogged. Need to remove the arms and clean them.
3. If it has a spray arm in the top rack, check to see that the piping for that is not broken or missing any pieces.
4. Any filter screens inside the plumbing could be clogged. This would slow down the spray and result in the dishes not getting rinsed properly. Check the inside of the machine for any foreign objects (see #3 above).
5. The machine might not be emptying between portions of the cycle. After the wash cycle, see if it is draining by either checking for water coming out of the drain hose or by opening the machine before it should start filling up for the rinse cycle.
6. Machine could be overloaded. Or loaded with extremely dirty dishes. Or with foods that are hard to clean like grits or oatmeal.
7. The machine could be improperly loaded. Bowls or platters blocking the spray. Tall objects like glasses and jars should not be loaded into the corners of the racks. The corners do no get a lot of spray and tall items can end up dirty.
Dec 22, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Nov 17, 2008 | Dishwashers
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
Food particles on washed plates
Sometime food particles stick near the door gasket. First, try changing the DW soap brand.
Nov 16, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
76 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
