Question about Xerox 6180MFP/N Printer
Erreur 17 988
Scanner does not work
Code erreure c3100 pour taskalfa 180
Scanner carriage error
The home position is not correct when the power is turned on, at the end of a reading process of the table and document processor.
May 13, 2014 | Kyocera Office Equipment & Supplies
Contacter le sav erreur sc 172
Il s'agit d'une erreur avec le scanner :
Scanner DA3 Abnormal/Video Processing
Error 3
Il faut probablement un technicien pour ca.
Apr 06, 2014 | Ricoh Aficio Office Equipment & Supplies
Erreur c3100
error c3100 is a scanner problem, try cleaning and lightly oiling
scanner rails, if this does not help may be scanner motor or pcb.
also check if scanner shipping lock is pushed on
Feb 25, 2014 | Kyocera FS Office Equipment & Supplies
I HAVE CODE ERREUR WITH CANON ADV IRC2020L; the machine display code erreur E248.001
Have you downloaded latest update prog.
Remove the old programme then reinstall latest update.
Jan 28, 2013 | Office Equipment & Supplies
Aficio 1232c erreur 122
SC122
[Cause]
SDRB board is faulty.
[Resolution]
Replace the SCRB board and ground.
AND
SC122 occurs while scanning.
Does not occur when scanning at the same magnification; occurs when copying and enlarging.
[Cause]
Scanner motor is faulty.
[Resolution]
Replace scanner motor.
And one thing to check is to make sure the set screw that locks the cable pulley to the scanner drive shaft didn't back out or shear off.
Sep 22, 2011 | Ricoh Aficio 1232C Color Copier
Erreur 107 (net::ERR_SSL_PROTOCOL_ERROR) : Erreur de protocole SSL i can,t open gmail
when i want to open my facebook count it comes this message Erreur 107 (net::ERR_SSL_PROTOCOL_ERROR) : Erreur de protocole SSL pleasssssse help
Jan 17, 2011 | HP Pavilion DV5234US Notebook Laptop
J'ai par erreur désinstallé mon scanner
Commence par deleter Director Player . Va ensuite sur Device manager ( gestionnaire des p?riph?riques ) et delete ( pas seulement d?sinstaller ) le pilote du scanner .
D?connecte le scanner . Va dans le Control pannel ( panneau de configuration \ programmes ) et delete le logiciel de ton scanner . Fais un restart .
Ne connecte pas encore le scanner . R?installe le logiciel pilote . Fais un restart . Attends que le systeme d' exploitation soit compl?tement stabilis? .Reconnecte le scanner et attends confirmation que le pilote est correctement install? . Cela devrait marcher ? pr?sent .
Si oui , r?installe Director Player et vois ce qui se passe .
Dec 13, 2010 | HP ScanJet 2300C Flatbed Scanner
Je ne peux scanner les documents vers le pc
êtes-vous employant le logiciel pour balayer au PC ou êtes-vous balayant de l'imprimeur lui-même ? Te donne-t-il une erreur ?
Jun 13, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Erreur laser
If your device is displaying 'Laser error' then you most likely have a faulty Laser Scanner unit
This will need a service technician to repair / replace it.
May 16, 2009 | Samsung SCX-4521 All-In-One Laser Printer
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
Xerox 6180MFP/N Printer Logo
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
