Question about Hasbro Fur Real Friends Smores Pony
My daughter has broken off her furreal pony's ear can it be sent away to be repaired?
You should ask a professional to fix it but i dont know and how did your daughter break it .hope it gets fixed ^^
Posted on Jul 01, 2009
I need an ear for Butterscotch pony 76471
Hey, replacement parts for Butterscotch can still be found on ebay, here's a left one: https://www.ebay.com/itm/263517990851
May 04, 2014 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony head not working
First, calling poor Grace at Hasbro will provide fruitless. Hasbro does not make any parts for the full size FurReal Ponies, they have nothing in stock and cannot help you. I, however, can. I am going to post a link to a distressing site that turns the normal FurReal Pony into a fire breathing demon. However, in the process, you can see the diagram of the skeleton of the pony and head. You can search for other links but this is pretty comprehensive. Just don't open when kids are around.
Lisa
http://www.instructables.com/id/Make-a-Fire-Breathing-Animetronic-Pony-from-FurRea/
Dec 08, 2013 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony makes gallop sound but very loud whirring noise at same time and head doesn't move side to side
Hey, that sounds like something in your pony's neck mechanism broke. Sadly Hasbro doesn't repair these ponies anymore and you have to investigate it yourself. You can follow this tutorial on removing the head: Hasbro FurReal Friends Smores Butterscotch Pony Head Removal How To...
Mar 17, 2013 | Hasbro Furreal Friends Butterscotch Pony
Need to get butterscoth furreal pony repaired
You can get replacement carrot stuff from butterscotchsmores.com and harness from Oksanas*Heirloom*Treasures on eBay.
Feb 14, 2013 | Hasbro Furreal Friends Butterscotch Pony
Butterscotch pony
Hey, the blue and grey wire under the neck fur does not connect to anywhere. It was likely a debug port while Hasbro was testing the ponies. You can try moving the ear by hand when it's supposed to move but it is likely broken inside the head and would need a lot of work to repair.
Jan 06, 2013 | Hasbro Furreal Friends Butterscotch Pony
Our furreal butterscotch pony has a broken
Can you be more specific? Is the neck broken? Or just the ears?
Nov 28, 2010 | Hasbro Fur Real Friends Smores Pony
My daughter has broken the tail off. Can we
Had the same problem and the fix is easy. Hopefully, the tail snapped off at the base of the plastic plate on the tail. If so, go to a hardware store and buy 1 ft. of plastic tubing with 1/4" inner diameter and 3/8" outer. Cut off a piece about 1 1/2". Now, look at the base of the tail and you should see a small screw that holds in what remains of the stub that broke. Unscrew the screw and remove what is left of the stub. KEEP THE SCREW. Now drill a small hole thru the plastic tube about 1/8" from the end. This will later be inserted into the tail and the screw will go through the hole. Next, take a hair dryer and heat the undrilled end of the tube to soften it and push it on to what is left of the broken stub inside the pony. It will be a tight fit which is what you want. The end of the tube with the hole should be just visible. Now slide the tail over the end of the tube and insert the screw. I just did it today and it works good as new! If the tail is too far away from the body of the pony, carefully remove the tube and shorten it. Since you bought a 1 ft. tube, you can have several trys to get it right! Total cost for the tube was 21 cents. Good luck! Kip V. Tryon, NC
Feb 07, 2010 | Hasbro Furreal Friends Butterscotch Pony
I need to replace an ear on my Butterscotch pony
Were you ever able to locate an ear for this horse? Hasbro doesn't sell them anymore... I need one too, so if you found a source, PLEASE SHARE!!! Best of luck!!
Sep 06, 2009 | Hasbro Furreal Friends Butterscotch Pony
Hasbro Fur Real Friends Smores Pony Logo
568 people viewed this question
Top Hasbro Toys Experts
Marvin
Marvin
Jesse Walters
Jesse Walters
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
