Question about Mackie HR824-MK2 System
HR824-MK2 no power not powering up
I don't know what it could be, one it just would not power up! I have replaced the internal fuse, which had blown. Other than that I don't know what it could be? Please help!
2 Suggested Answers
  • 5603 Answers
SOURCE: srm350 active-2 internal fuses on pcb-one had
Either a short in the power supply such as diode(s), capacitor, or transistor(s) or in the power amp. It will require service. Replacing the fuse before repair will likely damage more components... don't do it!
Posted on Nov 28, 2010
Image problems on my lcd tv
The internal power output maybe need replacement.If you have outage power loss the IPU receive to much voltage when the power restore and become faulty
Jul 16, 2013 | Televison & Video
I have a 2006 Dodge Caravan and the heat, radio and wipers quit working, as well as power windows? Replaced battery and replaced a big bwd fuse, alternator? What may be causing this and is it common in...
Their is a problem somewhere and answer is the blown fuse in the power distribution box under the bonnet ,so no doubt its blown the fuse again and the answer is to find out why ,if it hasnt blown the fuse again then their is a break in the power cable to where it goes to next which is the internal fuse box so check the cable froim the big fuse to the internal fuse board for damage .
Feb 22, 2013 | Cars & Trucks
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
SAMSUNG SP-50L7HX DEAD FUSE BLOWN BLACK OBVIOUS SHORT CIRCUIT ANYONE KNOW ANYTHING IF BOARD REPAIRABLE O
Try shopjimmy.com who carries almost all the Samsung boards--if fuse right where power cord does come in trouble is right there.
Aug 30, 2012 | Samsung Televison & Video
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's...
Most likely the unit does not receive power from main transformer. Possible several reasons:
- bad power transformer
- bad main internal fuse 7-8amp. Bad fuse most likely because of one of the channel is blown and shorts the power, so before installing new fuse good idea to check all channels by meter or at least visually for burned parts
- bad power relay
- bad connection, cracked soldering joints
Jul 18, 2011 | Denon AVR-1602 Receiver
Cerwin vega avs sub8. no power. changed blown fuse and still nothing. no power light indicator. unless led light bulb blew which i believe to be unlikely it has no power. any ideas
I got the same problem, my sub was working perfectly and suddenly one day it did't turned on, so I think it is the protection from the internal transformer, it needs to be changed but I don't know the model, if someone else knows I would appreciate the info because it is a really good subwoofer for the size...
Jan 07, 2011 | Cerwin Vega AVS-5.1 System
Connect to tv
Put a sound system between them and the TV, or better yet get the TV-audio from the Cable/SAT box in digital.
Jun 12, 2010 | Mackie HR824-MK2 System
Old uniden cb radio. i have plugged it in and i know i'm getting power through the cigarette lighter, but no power when i turn on the radio. no lights, no sound, nothing. please help. any ideas?
Hello there
There is a internal fuse on the inside of the unit that might need to be replaced and also check the fuse that is in the power cord ok?
best regards michel
Sep 14, 2009 | Uniden Radio Communications
Mackie HR824-MK2 System Logo
96 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
