Question about YouTube Videos
I have 2002 Avalanche, My problem is when I turn the key too start the truck it wont start I have too do this about three time before it start up. could you help me with this problem.."
    Problem Solver:
  • 5 Answers
Do you hear anything at all when you turn the key?
If not probably the battery...kaput. (How old is the battery?)
More than three years? I'd start there and make sure you check to see if you have a warranty position on it as well...
Posted on Mar 21, 2014
  •  Turco
    Turco Mar 21, 2014
    GM had a batch of bad ignition systems starting with certain models as early as 1999 all the way up to 2014. When you turn the ignition on and you get nothing at all, chances are that is the problem. Make sure to clear the battery possibility as mentioned. If you get the instrument panel to light up, then I would start focusing on other components (starter, O2 sensors, fuel pump, etc.) depdending on the othe symptoms which you didn't share. In the future, you might want to include the mileage of the vehicle, any previous issues and/or services it had and other relevant info that could help pinpoint the issue.
Wont start but it turns over dieg.ok on 2002 avalanche
do you have gas in it? or a blocked fuel line? Diagnosis will only show your the electrical side of the equation
Mar 27, 2014 | 2002 Chevrolet Avalanche
Start Up
That can be anything from the ignition switch, to the key going bad, to some wiring. First try to go to advance auto, and see if they can run a diagnostics check. Or if you want, you can disconnect the positive battery terminal, or negative, and let it sit without power for a few hours. That will reset the computer on the vehicle. If that will not work, take it to your local Chevrolet dealer, that has the repair shop, and have them look at it. The ignition is a funky little thing. My 2002 Chevrolet Malibu ignition just stopped working on me, I pulled the switch out and replaced it. But it never caused the car to cut off on me. It just seized the key in there and wouldn't release it.
Good luck to you.
Mar 21, 2014 | YouTube Videos
2002 chevy avalanche starts but wont take gas
Check fuel pump relay under hood and fuse.If they are good it is going to be the fuel pump.
Jan 06, 2013 | 2002 Chevrolet Avalanche
I crank my avalanche 2002 about 3 times before starting could be the fuel pump
sounds like the check valve in the pump is letting the fuel drain back try just cycling key a few times before starting this will prime pump and lines. if cranks up this is most likely cause a fuel pressure gauge will confirm
Aug 23, 2011 | 2002 Chevrolet Avalanche
2002 chevy avalanche died at a stop light and now wont start back up. it just cranks.
Those are known for having the fuel pump go out. Take the gas cap off, open the little steel door with a screwdriver and have someone turn the key forward, not cranking it over, just turn it until all the dash lights come on and see if you can hear the fuel pump kick on for about 2 seconds. You definitely need 2 people to do this. If you can hear the fuel pump then its probally not getting spark.
Jul 10, 2011 | 2002 Chevrolet Avalanche
Ignition is locked, recently changed battery & now can not start truck. tried reseting alarm by unhooking battery, turned steering wheel also played w/ gear shifter to no avail. 2002 avalanche
Turn on the ignition with engine OFF.
Try to start engine, then release the key to ON
Wait 10 or more minutes till SECURITY TELLTALE turns OFF.
Turn OFF the ignition, wait 5 seconds.
Repeat this procedure 3 more times, it takes 30 minutes.
You must turn the ignition key OFF before starting the engine.
To be on the safe side OFF means take the key off, and hold on your hand for 5 seconds.
If you missed something visit GM dealer, and they gladly will provide you a print out of this procedure.
Sep 05, 2010 | 2002 Chevrolet Avalanche
Avalanche alarm goes off and key wont start
Try disconnecting the battery cable for a few minutes. This may clear the security code and allow the normal key to operate. The sensor in your tire may have gotten damaged when it was repaired (this is not uncommon). The solution, take it to a tire store, they can change the sensor if needed.
Jul 06, 2009 | 2005 Chevrolet Avalanche
My 2002 Chevy Avalanche starts briefly then turns off What could be the problem?
Possible bad engine crank sensor. Electronic Control Module provides initial timing for start then depends on the crank sensor once started for timing and firing
Apr 23, 2009 | 2002 Chevrolet Avalanche
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
