Question about Aurora Electronics AS890C Shredder
How do you remove the shredder head off of the fellowes shredder dm17cs
How to remove the shredder head.
How to repair flellowes shredder
Without further information as to the exact issue you are having, here is a like to YOUTUBE with various videos on shredder repairs.
http://www.youtube.com/results?search_query=fellowes+shredder+repair
Jul 10, 2014 | Fellowes DM17CS Confetti-Cut Shredder
How to open fellows s701 cm shredder?
There are six Phillips head screws around the perimeter of the underside, plus one more hidden screw in the center under a label. Then the cover just lifts off ...
May 18, 2014 | Fellowes S701CM Shredder
Where can I buy replacement nylon fellowes gears
Have you tried http://www.hpcgears.com/? They're a good company to deal with and stock a huge range of gears for many machines.
May 10, 2014 | Fellowes DM17CS Confetti-Cut Shredder
Led sensors on the bottom
superflykitt:
Disconnect the power cable and remove the cutter head from the top of the paper bin. Turn the shredder head upside-down and remove the screws holding the shredder head cowling together. Open the cowling and you will see the slot where the sensor fits (on one side of the paper feed slot bottom side.
Aug 29, 2012 | Fellowes FS5 Shredder
Open the head cover
There is a seventh screw under the label.
Apr 07, 2012 | Fellowes P50CM Shredder
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
May 25, 2011 | Fellowes Office Equipment & Supplies
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
DM17Cs turns on for just a second then clicks off
Pulse timing wheel is dirty. Blow out with canned air. It's a small black disc with slots in it.
Jul 31, 2009 | Fellowes Office Equipment & Supplies
Fellowes 220c-2 gear or shear pin?
The Fellowes 220C-2 has a history of gear breakage. I've replaced dozens of them. Not a major operation. They're made of plastic and break way to frequently. Replacement requires that you remove the cutting block and it's held in place by 4 nuts threaded onto studs that require the deep well socket to remove them. I'd advise letting a professional handle it. The gear costs about $12-15 and most Fellowes dealers have them in stock.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 16, 2007 | OfficeMax 0M96431 Shredder
Aurora Electronics AS890C Shredder Logo
91 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
