Jammed. will not forward or reverse. How to dismantle it?
How to take it apart? There are 6 screws.
  • 20 Answers
Dear Debbie,
Here is some generic information about shredders that may help you.
If you remove the "head" unit from the bucket, most of the shredders have screws fixing the housing top and bottom parts. Manufacturers normally use Philips type screw heads. Some shredders have the screws mounted under the sticker on the top of the unit. Therefore, if you do not locate the screws in the internal part of the head unit, they are certainly positioned under the top stickers/labels/control panel.
If you can locate the screw heads, make sure you do not use a smaller than the screw head size. Using smaller tolls may damage the screw head and then you may be unable to remove the screw unless you have special tools. Also, please remember the standard screws are released by turning the screw driver in a counter clockwise turn.
If the 6 screws you referred to are visible and easily reachable just follow the instructions above to unscrew them.
I would recommend you use a digital camera to take pictures (or take notes) to follow up the dismantling task so you will not get confused (or lost) when trying to put it together.
Make sure you dismantle it properly UNPLUGGED from the power as you will find "live" contacts inside the unit.
You may be able to pull the pieces of paper (or strange material) that caused the shredder blades to get stuck. You can also use a longneck plier to help pulling the debri out. After the shredder blades are clean, use a little bit of silicone grease to keep the gears running smoothly.
I hope this gives you some light in further investigating your problem.
RC
Posted on Jun 17, 2014
Why does the motor run in reverse but not in forward switch?
Could be a disconnected wire at the switch, a bad switch, or its jamming in the froward rotation, you will need to take it apart to see what the problem is. Not super difficult, but if you do me very careful as the blades are very sharp, and take images of is as you dismantle it so you get it all back together correctly. Don't forget the blades also need to be oiled once in a while. To oil turn it on in reverse, run a small line of oil along the length of the blades, let it run for 10 seconds, and you;re done.
Mar 21, 2015 | Office Equipment & Supplies
How do you clear a paper jam
Typically the best way to clear a paper jam in a paper shredder is to run it in reverse then forward repeating this as many times as necessary to remove the jam (sort of the same as rocking a car back & forward to get it out of a mud or snow rut). If that doesn't work then the only option is to take the shredder apart and clear it that way!
Good Luck!
Rich Lilja
Mar 16, 2015 | Office Equipment & Supplies
How do i clear jammed cutter blades
Does the shredder have a reverse button ?
If it has, just switch between reverse and forward a couple of times.
If that does not work it may have to be dismantled and the cutters turned by hand as you pull the paper out. Disconnect the power first though.
Dec 17, 2014 | Office Equipment & Supplies
Remove hard drive for hp pavilion s3220n
Pretty simple. Just dismantle the case of your desk top. most of them will split open so you can leave it standing . There will be about 6 to 8 screws holding this together and a few "snap" type connections that pull apart. Remove the base first. Once inside identify the hard drive. unplug it and remove. Probably two screws holding it in place. Reverse process for installing new one.
Aug 30, 2014 | HP Pavilion S3220N Slimline Desktop PC AMD...
I have paper jamed in my shredder, I can't reverse or forward. How can I clear the jam?
You may have to take it apart to clear it by hand...remove the bin, remove th screws from underneath inside the cabinet and take the cutting head off the cabinet. Turn it over and remove the screws, turn it bak over and take the top off to see the insides.
Oct 01, 2010 | Royal 160MX Shredder
My swingline electric stapler model 42130 is jammed is there a manual release button the one on the back doesnt work
Taking the stapler apart is a complex task if you can figure how to do that.To dismantle the stapler, slide back the top, remove two small screws on both sides, six on the bottom, four of the screws are under the sticker so you must peel off the sticker, you must also remove the sticker on top. There two tiny shinny screws at the bottom once you are inside. Now you have access to more screws you can take off to get to the staples place where the jam is. Watch cables where they are plugged to in case they come off. If you are are a mechanical technician or technically inclined you might be able to fix this yourself but you must be very patient.
Aug 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Will not go forward
Probably the gears or other parts are jammed with the plastic and sticky substance.
Make sure it is unplugged. Then see how to take some of the unit apart. Many of these kinds of units will be held together by screws in deep indentations. You will need a screwdrive of the type of the screw-head. Remove the screws and then you can split the unit apart and see what the problem is.
More than likely, it will be a matter of removing the sticky plastic jammed into the unit between the gears and or the rollers or other parts.
Jul 26, 2008 | Aurora Global AS702MX Shredder
Shredder won't shred any more.
I have the Infoguard SX100M Axeus, sold by Staples.
Only the reverse was working, UNPLUG and open back cover, the paper mechanical switch was working fine, red side switch, the gears and fuse were all ok, I think something on the circuit board was fried.
I switched the BLACK and WHITE wires with each other going to the shredder motor, thus when I switched it to reverse, it would go foward and shred. Its working now, only in reverse.
Mar 27, 2008 | Office Equipment & Supplies
90 people viewed this question
jasbo
jasbo
