Question about Haier DW12PFE2U Dishwasher
Dishwasher won't start
Dishwasher was started and door opened around a minute later to add something. Since then, all we get is 1 flashing light when trying to use and dishwasher wont start. Have tried cleaning drain hose etc
SOURCE: Open the dishwaser while still filling now keeps going to error
After reading a few of the other Haier models troubles, I pulled the unit out and tip it at 45 degrees backwards for around minute. Water pored from the back of the unit, once cleaned water up reinstalled unit and all seems to be back in working order.
Posted on May 18, 2009
SOURCE: haier dishwasher
I useto have same problem. For some reason there was water under machine, then i tilted machine, clean water and problem solved. This is built-in dishwasher that is why water acumulates under machine and "leak cut off switch" turn off machine. You can't reset machine while you have water under, machine telling you there is a problem, but Haier wan't put solution on their site - Haier suport is very bad. Sorry for English and hope this help.
Posted on Jul 26, 2009
SOURCE: Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Posted on Jan 12, 2010
  • 62 Answers
SOURCE: dishwasher will not empty
check to make sure nothing is binding the impeller, ie: broken glass, coins, twist ties, plastic bag.
Posted on Feb 16, 2010
  • 126 Answers
the drain hose has to loop up to the height of the washer and then drain?
Posted on Mar 25, 2010
After a few minutes into cyle delay lights start flashing
Light(s) Flashing/Blinking - Door Opened - Delay ... - Maytag
www.maytag.com/...light(s)-flashing-blinking...delay.../PH7053/
MaytagQuestion: Built-In Dishwasher - Light(s) Flashing/Blinking - Door Opened - DelayWash - Cycle Power. Answer. Product Symptom: Built-In Dishwasher - Light(s) ...
Sep 26, 2015 | Bush Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Lights flash on dishwasher but it won't turn on
maybe a problem with the sensor 'door open/door close' check if its dirty or stuck if mechanical. press door to close and hold tight close while starting to identify.- or no sufficient water supply- or used water cannot drain out
Jun 15, 2012 | Frigidaire Dishwashers
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
Dishwasher was opened to add dish and would not start back
give it a few minutes it may have a built in delay when cycle is interuptede
Jun 01, 2009 | Dishwashers
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light flashes
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Start/reset button flashing
The GE technician came to my place this morning and here what he told me.
The start / reset button is used to reset the current wash cycle. You just have to close the door and 90 sec later the dishwasher will be ready to start another cycle. This button is used usually to cancel a wash cycle.
A more drastic measure is to turn off the dishwasher breaker in the electric panel for 30 minutes in order to clear the memory of the panel. After 30 minutes, turn on the breaker and the dishwasher will be back to the factory defaults.
At this point you should not have any problems.
Michel
Jan 16, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Haier DW12PFE2U Dishwasher Logo
21 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Tom Chichester
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
