Question about Music
Marshall mg 50 dfx amp sounds muffled?
I have the exact same amp as my girlfriend and it sounds fine, but hers no matter what adjustments to the knobs it still sounds like it's under water. Any way to solve please?
    Sergeant:
  • 336 Answers
Turn off the effects or go inside and unplug the little sound card. It is only a few samples of real effects, not the real thing. It's like a cheap PC sound card separate from the other components and has a small power plug on it. Wiggle that plug or unplug to see if it changes. It won't cut her sound, just the effects. Make sure the effects are off and verify, if using a footswitch, that it is working properly.
Posted on Mar 29, 2014
  • 5603 Answers
SOURCE: Hi,I turned on my Marshall mg series 100 dfx and
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Posted on Sep 03, 2009
  • 5603 Answers
SOURCE: Marshall MG50 DFX, the volume knob OD channel crackles
Either the control is damaged (happens if they get hit) or it is possible the circuit board it is mounted on has broken solder OR worse, a crack near the control. The unit will require servicing. Parts are readily available.
Posted on Jan 31, 2010
AndroidLVR
  • 31 Answers
SOURCE: Marshall MG50 DFX amp line out/headphones not working
Well, your problem isn't very descriptive to help troubleshoot online, but first question would be; are you using the correct size jack? The second would be have they worked before? If the answer is yes to both questions, then the problem might be the jack itself on your amp. There is a prong inside the headphone line that hugs the plug to your phones. If the prong has loosened enough where the connection is poor or not at all, you will not get any sound. If the headphone jack has NEVER worked before, than it sound like a wiring issue on your board somewhere. If you are not familiar with a soldering gun, then I would take your amp in to get it fixed. should be a minor quick fix costing anywhere between $15-$30 to have a shop do it. Hope this helps. (also try different headphones if you haven't already. Could be a bad pair)
Posted on Mar 09, 2010
  • 94 Answers
SOURCE: i have a marshall mg
NOT SURE WHAT FLUG MEANS? IF YOU MEAN PLUG. CALL GHOST BUSTERS.
Posted on Oct 25, 2010
  • 5603 Answers
SOURCE: My Marshall MG 50 DFX has a noisy fan. Can I take
Bo, the fans cannot be lubricated. If the noise is from bearings, replacement is the only option.
Posted on Dec 06, 2010
Greetings. My MG 250 DFX Marshall 100W amp behaves strangely... I had some problems with it lately. I've been using it for a few years in my flat, so it has not been used extensively in terms of power...
I believe the design of this results in what you are seeing... Check each speaker INDIVIDUALLY plugged into the MAIN output as plugging into the second jack shifts the tap of the output transformer to the 4 ohm tap which results in a 6 Db drop but now you have two speakers... the apparent level change will be almost unnoticeable.. Do comparision of the speakers individually using the MAIN jack. This is just the characteristics of the beast...
Jan 11, 2011 | Marshall Amplification Marshall MG250DFX...
My Marshall MG 50 DFX has a noisy fan. Can I take it apart and give a shot of oil?
Dec 05, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Ihave a marshell dfx 100 guitar amp...as i play it the volume lowers and will eventully fade to nothing... any ideas..
For a test in troubleshooting, see if level from the headphone jack fades or not when this happens and get back to us.
Sep 02, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
By mistake i plugged the speaker jacks from another amp into the speaker jack on my mg 50. i was trying to test the other anp with the speaker on the marshall but i did it wrong. i didnt turn the marshal...
If you connected an external speaker plug from one into the same type plug on another amp, you have driven signals backward into the amp that was off... NOT into the speaker in that unit.
The usual result is blown parts in the amp that is off.
Some amps have their own speaker cable that you can unplug to connect to another amp and that is fairly safe. NEVER run an amp without a speaker load on it.
Feb 20, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Jan 28, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I need the schematics for a Marshall MG30DFX guitar amplifier in order to repair it.
If you still want the schematics for the Marshall MG30DFX Steve I have them and can email them to you if you want
Dec 10, 2009 | Marshall Music
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Mg 50dx no sound
Contact Marshall on the web or try a search for exactly what you need, most companies will help you with there products no matter how old they are .
Mar 01, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
