Question about Bosch Dishwashers
My Bosch SMU 3000 DLX Series dishwasher doesn't heat the water
Doesn't heat the water
SOURCE: bosch dlx series SHU 3300
you need to remove the outside of the door to give you more room remove the six torx screws on the inside of the door sides only do not remove the top ones then the out side of the door will come off on give you room to work on it
Posted on May 08, 2008
  • 6 Answers
SOURCE: Bosch DLX series didn't drain, now no power
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Posted on Dec 27, 2008
SOURCE: Bosch Dishwasher Model SMU 2046
First check the screen in the water inlet valve ( you have to take off the lower panel below the door and disconnect the water supply. If that doesn't work or isn't plugged, replace the valve.
Posted on Jul 16, 2009
  • 142 Answers
SOURCE: I have a Bosch DLX Series dishwasher. The cycle
have checked it does get hot enough through the wash cycle.
Posted on Sep 14, 2009
Macmarkus
  • 2605 Answers
SOURCE: Our Bosch dlx series dishwasher
Welcome to Fixya ! You've come to the right place. The problem you're experiencing sounds like (unfortunately) a common one.
The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's.
The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic.com, apwagner.com etc.
Do a search for part # 1105846 at repairclinic ( that is their part # not B/SH/ ) you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward.
Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness.
Good luck.
macmarkus :)
Posted on Jul 28, 2010
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
Bosch dishwasher - the water doesn't come on
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 03, 2011 | Bosch 24 in. SGI43A72 Built-in Dishwasher
Bosch shx43c at end of cycle doesn't completely drain. leavs some dirty residue on dishes (water temp set at 120) cleaned filters water standing in lower filter basin (creates odor) and took hose...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 25, 2011 | Bosch Integra 300 Series SHX43C0xUC...
Our Bosch DLX series dishwasher slowly fills up when it isn't running. If we don't use it for a day or two the water will flow out the bottom. When it runs, it runs normally.
Hi, the problem is the water valve itself. Based on your description and the fact that this is a common issue with Bosch dishwasher's a new valve will resolve the problem. You'll need a new valve assembly part # 425458 and it's available at most part's places or online. It is about $25 - $30. Let me know if I can assist you further. Thanks for using "fixya" for your inquiry. Please take a second and rate the info provided for you here. Good luck. Macmarkus :)
Mar 21, 2010 | Bosch SHU9915UC Dishwasher
Leaves a scum on the dishes
Sounds like your water temp is too low,there is a heating element in the bottom that heats the water that is circulated,if it goes out it wont get hot enough to dissolve the soap,or clean your dishes.its not to difficult to replace.
Hope this helped.Let me know by rating me, or
For more help go to live chat.
lenwest
Jan 30, 2009 | Bosch Nexxt DLX WFMC4301UC
Bosch wont
Faulty inlet valve or water in the bottom tray which will activate the float swich and pump out any water. See that this moves up and down freely. Turn electrics off first.
Jun 18, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dlx series SHU 3300
May 04, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
No water on wash cycle
YES YOU ARE RIGHT TIMER COULD BE FAULTY OR WATER INLET SOLENOID COULD ALSO BE BAD
Feb 02, 2008 | Dishwashers
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
