Question about Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S
Galant 2007 ignition module
Not firing
1998 Mitsubishi Galant 1.8 GDI (EA1A model) starting problem. So it's not starting but turning engine over. Checked the spark plugs and they were oily. Cleaned them and still not firing. checked to see if...
Dude....putting 2 stroke fuel into a 4 stroke engine is just silly, but not where your problem lies. Check the coils to see if it is generating spark...if not then check the ignition module....even 'oily' the plugs should fire.
Oct 30, 2014 | 1998 Mitsubishi Galant
Not firing
Hi Des, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose/broken connections at battery terminals/cables, especially the "NEGATIVE" cable at both ends, ignition coil, or plug between ignition sensor and module.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, and/or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damaged intake or exhaust valve.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
DOWNLOAD 2007 Aprilia Etv 1000 Caponord
Jul 02, 2014 | 2007 Aprilia ETV 1000 Caponord
2002 galant will start up fine cold and run for 20 min, after hot soak will not start, back fires through intake
Yes your 4 cyl engine uses direct spark with a coil over each spark plug.
And the computer controls the firing of the plugs and injector pulse.
The problem could be the crank or cam sensor, or the wiring harness, but in most cases the check engine light should be on and a code set.
You might want to check the computer for codes, then try the cam sensor.
Sep 22, 2012 | 2002 Mitsubishi Galant
2003 mitsubishi galant coil pack problems
Does your car have a igniter or Imignition control module(ICM)?... That's what tells the coil when to fire on my car.
Jun 13, 2012 | Cars & Trucks
Cylinder 1 is not firing
Instructions1 Use a wiring diagram for the year model of your vehicle. Locate the terminals running into and out of the ignition module. Placement of the module varies from model to model so check the appropiate service manual of your vehicle for the exact location.
2 Turn the ignition on and use your DVOM to check for voltage to the ignition module and the positive terminal of the ignition coil. Place the negative lead of your DVOM to a solid ground and use the positive lead to probe the wires running to the ignition module and to the ignition coil.
3 If your DVOM shows that voltage is present at both locations, remove the DVOM leads and set the meter aside. Connect the ground lead from the 12-volt test light to the negative terminal on the ignition coil. Have your partner crank the engine over several times. Your test light should flicker on and off. If so, your module is working properly and no further testing is necessary.
4 If your test light does not flicker on and off, visually inspect the wires running into and out of the ignition module. Look for burn marks, melted wire insulation and breaks in the wires. Use your wire splicing tool to remove the bad area in the wire and use your wire connectors and splicing tool to repair the faulty wires.
5 Use your DVOM to check for an open circuit condition in the primary coil winding. Touch the negative probe to the negative terminal on the ignition coil, touch the positive lead to the positive terminal. Set the meter to read ohms. If the reading shows infinite ohms, your ignition module is faulty and should be replaced. Follow the service manual instructions for replacing your ignition coil.
6 Look to see if the DVOM test shows low to no ohms; if so, then you have a faulty ignition module that will have to be replaced. Follow the service manual instructions for your vehicle to replace the module.
Thanks
Apr 02, 2012 | 1994 Mitsubishi Galant
My 2002 Mitsubishi Galant will not start. When we try to crank it, we smell the gas. We've took it to the shop and put in a new fuel pump because they thought that was the problem. It was not the fuel...
DID YOU CHECK THE IGNITER/MODULE THAT'S IN THE DISTRUBUTOR,CHECK THAT AND COIL,YOU ARE NOT GETTING FIRE.(IGNITION)DON'T TAKE IT SOMEWHERE THEY JUST GUESS TAKE TO SOME ONE WHO TESTS,ALWAYS A GOOD RULE.
TIM.......
Nov 04, 2010 | 2002 Mitsubishi Galant
3 and 6 ignition coil do not fire
The module or computer might be bad.
Jul 05, 2010 | 1994 Mitsubishi Galant
Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
