Question about Coleman Powermate Powermate 5000W Generator
I have a porter cable 5250 generator that bounces off the governo
I have a porter cable 5250 generator that bounces of the governor making the voltage jump around helppppp!!!!!!!!!!!!!!!!!!
  • Sheldon Dedek May 11, 2010
    If I understand correctly, the governor is bouncing around. Or is the generator bouncing around, causing the governor to have problems? More details please.
  • 4 Answers
There 2 linkages that conect that would be the problem. you have on conected to the throttle switch that runs to the govener than on that govener os another linkage hooks up to it and runs to the carborator that ajusts the flow. if you don't have both linkages than you need to order 1.
Posted on Oct 25, 2009
What spark plug does a porter cable BS1525w take
The Briggs and Stratton part number is 591043 sparkplug
Nov 30, 2015 | Porter Cable PorterCable BSI525W 5250 Watt...
When I spray starting fluid in carb it starts but won't stay running
It is not getting gas. Check there is gas in the tank, the fuel tap is working and the float in the carburettor isn't stuck.
Aug 16, 2015 | Porter Cable PorterCable BSI525W 5250 Watt...
What type fuel does a 5250 porter cable generator take
From p.10 of the manual
"Check fuel level, fill as required. Make sure generator is turned off and has been allowed time to cool down. Use clean, fresh, regular unleaded gasoline with a minimum of 87 octane. Do not mix oil with gasoline".
(taken from bottom of this webpage
http://www.cpoworkshop.com/porter-cable-bsi525-w-5-250-watt-electric-generator/pcbnbsi525-w,default,pd.html?cgid=porter-cable-delta-discontinued )
(Is this your exact model ?)
14.April.2014
Apr 14, 2014 | Electrical Supplies
THE VOLTAGE COMING FROM THE GENERATOR IS NOT RIGHT. iT WILL BLOW A LIGHT BULB INSTANTLY
Connect a voltage meter to the 115v plug and measure voltage. If too high, adjust governor spring tension to compensate. Your engine developes max horsepower at about 3600 rpm. At this speed the generator should be producting 115v at 60 cycles. Good holidays
Dec 17, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
This is for the Porter Cable H650IS-W-1 Contractor Generator. It has an idle/RPM control solenoid that adjusts to the load on the generator. I can see that the solenoid works because 9VDC applied to it...
I do not think that your generator has a voltage regulator. The solenoid is for idle only when there is no demand (power being used). You can verify this by examing the governor spring /tension adjuster on the engine. Idle control switch on panel and the assembly board control the solenoid. When the assembly board fails generally the generator will function the same however there will be no idle. I have checked with Dewalt and parts are available however expensive. If idle is the only problem you may consider ignoring issue. If there is another problem with gen. please email.
Nov 13, 2010 | Porter Cable 6,500 Watt Contractor...
What type of oil do i take for a porter cable 5250 watt electric generator?
Your generators take ordinary 10W30 motor oil.
We use these things on the job.
Don't turn engine upside down or on its side to drain oil, or oil will run into carburetor
Oct 24, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
Need to reset manual governor on 10 hp briggs and stratton mod # 205412 type 0178-E1. took pan off the governor does not look bad or broke wasker under the governor looks good. I think someone moved the...
First loosen the pinch bolt and nut on the govener arm at the governor shaft. To set the governor make note of the governor arm to open the thottle wide open. Hold the governer arm to where the throttle is wide open then turn the governor shaft that is coming out of the engine block in the same direction until it stops then tighen the pinch bolt and nut on the governor arm to hold the arm in position on the governor shaft. Make sure when you start the engine you don't over rev it. Start it in low speed and move up slowly. You may need to reset the spring tension.
Dec 14, 2009 | Briggs & Stratton Power Products 5,550...
Coleman Powermate Powermate 5000W Generator Logo
293 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
