Powermore 277 cc
After refilling the gas today I went to check the oil .To my surprise the dip stick wouldn't pull out after unscrewing the cap.I finally yanked it out and found the end missing and the bottom 2 inches mangled.How did that happen ?
    Top Expert:
  • Computers & ... Master
  • 21,456 Answers
I would take the engine apart and investigate, urgently before the main bearings get mangled!
Posted on Mar 21, 2014
2 Suggested Answers
  • 8404 Answers
SOURCE: i need to put oil
Did you try pulling on the cap? Turning right or left? Your question is confusing ... I am not familiar with a "KA" PC Lap top ... I presume you are actually talking about a car and not a computer. Typically, cars have a "oil can", as you describe, on the oil filler cover.
Thanks for your question @ FixYa.com
Posted on Feb 10, 2011
2007 VW Rabbit 2.5L. have a Vacuum in Oil pan. Runs Rough when remove oil dip stick. can hear and feel the vacuum.
Probably bad PCV valve. The linked video came out in last week, and shows just what you describe with the oil filler cap or dip stick removal.
Rough Running Running Lean Volkswagen CC Sport
May 21, 2017 | Cars & Trucks
How much oil do I put in my car 19 00 cc
1. Turn off engine ,
2. Take of oil cap on engine
3. Put in a little oil in oil filler hole of engine.
4. then pull out the oil dip stick from engine
5. and clean the dip stick on a rag.
6. Put dip stick back in engine
7. pull out again and check the level showing on the dip Stick
8. If level is too low on dip stick and is not at full level go back to step 1
These steps ensures you avoid over filling the engine with oil
Tip for beginners
The 4 litre oil bottle is way too much oil for an engine to handle.
If you have a full 4 litre oil plastic bottle square shape . hold the bottle on its side to pour the oil out slowly and smoothly.
Jun 04, 2016 | 2005 Mitsubishi Carisma 1.6
Where is the oil dip stick located on 2002 cavalier
On most Cavalier motors the dip stick i s part of the filler spout you just remove the filler cap and pull the stick out with the cap. Make sure you check the oil with the motor shut off
Sep 23, 2014 | 2002 Chevrolet Cavalier
Where do i find the dip stck for the gear box oil . and where do i refill with new oil?
The Sportster does not have a dip stick for the transmission/ primary oil. You just pour one quart of oil in through the upper inspection hole.
On a Big Twin, there is a chrome endcap on the right side of the transmission. In the end cap, there is a plug that usually takes a large hex key or Allen wrench to remove. It has the dip stick on it. Stand the bike straight up to check the oil level. It should be between the two lines on the stick. The transmission holds 20-24 ounces of transmission lube.
Good Luck
Steve
Jun 18, 2011 | Harley Davidson FXDL Dyna Low Rider...
HOW DO YOU CHECK THE OIL LEVEL IN A 1981 HONDA 1100GL
There is a dip stick located on the right side of the engine about 4 inches to the front of the oil fill cap.
Make sure you are on level ground. Unscrew the dip stick and wipe it off. Replace the dip stick and then remove again. Check the oil level and replace. If you need to add oil, remove the filler cap and add oil 1 to 2 ounces at a time. Check the oil dip stick to ensure that your oil level is correct.
NOTE: warm up your bike before performing the above checks.
Regards,
Oz
If you find this helpful, please vote on it. Thank You.
Oct 19, 2010 | 1981 Honda GL 1100 Innerstate Gold Wing
NEED TO KNOW HOW TO CHANGE ALL OILS 2005 Electra glied classes harley
The oil tank is on the bottom of the transmission. The engine oil drain plug is on the left front corner of the oil tank. Drain the oil, change the oil filter, and refill with three quarts of any approved 20W50 weight engine oil. Check the oil level using the dip stick. The dip stick is located on the right side of the transmission. The oil cap is a large cap (2" or 50mm in diameter) with knurled edges on it. The dipstich has two marks on it. The top mark is 'FULL HOT" and the lower mark is "FULL COLD". Keep the oil level between these two marks. Check the oil level with the bike on the side stand.
Good Luck
Steve
Oct 03, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
How do i refill the transmission oil in my 1997 Micra auto (1 ltr). Can't find the cap.
Hi: To Refill your Auto Transmission with Tranny Fluid, There is NO CAP, Look For a Dip Stick Similar to your Oil Dip Stick.You Refill your Transmission where the Transmission Dip Stick comes out of a Tube. You'll Need a Funnel that Fits inside the Transmission Dip Stick Tube. This Should Resolve your Question. Please Vote and That actually sends me How Well I have Helped You. OH Look Towards the middle to the Back of Your Engine to Locate Your Tranmission Dip Stick: From the WYOCWBOY
May 30, 2010 | 1996 Nissan Sentra
We just bought a 05 chevy equinox 2 days ago. Last night the "service engine"light came on. My husband went to check the oil and cant find the dip stick.
If you don't tighten the gas cap (make it click at least four times) when refueling it will turn the check engin light on. The dip stick is located in the front of the engine and is a yellow loop.
Apr 05, 2010 | 2005 Chevrolet Equinox
How do I check oil level in my 83 goldwing interstate
if there is no dipstick there should be a window on the lower engine case with upper/lower lines to show you the level
Mar 19, 2010 | 1983 Honda GL 1100 Innerstate Gold Wing
I have a 1.5 hp 3 gallon craftsman air compressor. When I turn it on, oil shoots out of the vents in the oil cap? Why is this? How can I fix it?
hi mate it is probably due to too much oil and when it starts the oil inside is splashed out the oil cap i reccomend start the compressor and let it run for 2 mins to get the oil warm take the plug out and drain the oil and the refill with p68 oil and on the oil sight glass refill it untill it reaches the red dot in the middle if it has one or on the dip stick it has a measurement good luck
Jul 07, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
