Question about Homelite Garden
MY HOMELITE ST 275
I have replaced the fuel filter,& gas lines. It will run but unless I keep pumping the triger it will stop. Than after lot of adjustments it will run W/O the air filter ,but whenI I put the air cover on it stops . I, assume it must NOT be getting air . I don't see any place to check it out. What can I do?? Glenn
  • 3 more comments
  • gav412 Jun 16, 2009
    Jim;
    Thanks,do you know the actual setting for the H & L adjustment screws?
    Glenn
  • gav412 Jun 17, 2009
    Thanks Jim,
    I can't let this thing get me down ,but it is taxing my patients.
    I have taken it apart ,so many times I can do it in my sleeep.
    I even put all the old stuff back ,except the fuel filter[TOO much work]
    Still it just runs & just shuts off,like it is NOTgetting enough gas.
    before,I went through all this work, it started easy,but stopped after about 50 Ft. than all hell broke loose.
    Glenn
    Thanks again Jim; I'll lewt you know when I get it running!
    Glenn
    Jim;
    As I told you I would let you know ,what was wrong..It's just me ,as I put the gas lines ,on the wrong place. Remember when I told you,I had NO problem putting in a new filter. That was wher it started, my STUPID mistake,so please put this in your HELP file
    .Glenn
  • gav412 Jun 19, 2009
    Jim;
    I took the tube out of the tube out & put it in the right hole. ,So Now it is not twister.
    Glenn
  • 1,041 Answers
Hi Glenn,
First, check the fuel lines for cracks/breaks. Replace if bad.
If they are o.k.,then you will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
  • 2 more comments
  • Jim Parker
    Jim Parker Jun 16, 2009
    I always start with: 1 1/4 turns on each. And work my way up to two full turns, trying different combinations of each.
    Thanks for the rating. Good luck!!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
  • Jim Parker
    Jim Parker Jun 17, 2009
    Did you use the Den Tek Brush on the small portals in the carb. and check the screen? These two things are key to the problem.
    However, if the carb. parts are more than 4 years old, you may need to replace them, (new carb. kit).
    The reason you are getting frustrated is because your probably thinking that you are taking it apart one more time for nothing. Here goes another hour of my time! I've been there so many times in my life, that I'm now answering questions on FixYa.com. LOL !!
    Persistance my friend, persistance.
    Jim
  • Jim Parker
    O.k. Glenn,
    Well just in case, here is a solution to your fuel routing.
    The longest, and sometimes smaller in diameter of the two fuel lines, goes from
    the carburetor to the bottom of the tank. Leave enough slack in this
    line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
    The
    other
    fuel line goes from the primer bulb to just inside the tank,
    (about an inch). make sure that you get the right size fuel lines. The
    plastic coupling goes on the end of this line, inside the tank. This
    keeps the line from pulling out of the tank.
    (HINT): When feeding the lines through the tank holes, cut the lines at an
    angle. They will feed much easier into the holes. You can than cut them
    off square, once you know that you have enough to work with.
    Jim
  • Jim Parker
    Jim Parker Jun 19, 2009
    I didn't quite understand the last comment. Let me know when you get it running. I feel like I'm on a mission now!
    Ha-Ha!
    Jim
Why does my 2012 dodge ram 1500 fuel pump stay on...
About 117,000 results (0.73 seconds) Search Results
    TIPM Repair & Bypass Solutions for 2007-2014 Dodge ...
    www.verticalvisions.com/TIPM_solutions.php
    2011-2012 Dodge Ram 1500; 2011-2012 Dodge Ram 2500; 2011 Chrysler Town ... test your fuel pump relay, and bypass a bad fuel pump relay to stay on the road. .... Mytesting/bypass device will often narrow down your problem to the TIPM ...
    Dodge Ram 1500 Questions - fuel pump keeps running ...
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusNov 1, 2013 - fuel pump keeps running when key removed - 2011 ram 1500 slt quad ...fires right up but will not stay running unless I keep my foot on the gas.
    I Changed The Fuel Pump On My 97 Dodge Ram 1500. Ran ...
    CarGurusI changed the fuel pump on my 97 dodge ram 1500. Ran great for 2 days then stopped running. I can hear pump working, replaced fuel system relay, engine tur... ...Jun 24, 2012 at 03:48 PM about the 1997 Dodge Ram 1500 2 Dr ST 4WD ... The truck fires right up but will not stay running unless I keep my foot on the gas.
    2011 Dodge Durango Fuel Pump Relay Stays Engaged ...
    www.carcomplaints.com/Dodge/.../fuel.../fuel_pump_relay_stays_engag...
Feb 03, 2016 | Dodge Cars & Trucks
97 chevy suburban have replaced fuel pump, relay, fuel filter, & the fuel pressure regulator but now it will crank & then die once I press the gas pedal. It also bogs down after coming to a st
possible faulty accelerator position sensor. Have the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units
Jun 03, 2013 | 1995-1997 Chevy Suburban Ignition Starter...
Any special proceudres to starting an old ST-175 homelite weed trimmer that has not been run on over 8 years.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, 22
Dec 31, 2011 | Garden
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite UT2680 trimmer fuel line (25cc engine)
You can go to a small engine repair shop, parts shop or look on eBay and they should have the fuel lines you need. Not very expensive, about $1.00/foot for new Tygon lines. You are way overdue for replacing yours. The ethanol in the gas does a job on them.
Jun 09, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Gas/oil ratio
Homelite products are 40:1 gas-oil ratio.
May 26, 2010 | Homelite Mighty Lite Lawn Trimmer
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
Homelite ST-185 (15039A). Route new fuel line.
If you look closely there should be 2 holes in the fuel tank, also if you look inside the fuel tank there should be some remaining pieces of the fuel line and a fuel filter. If this has been sitting for any length of time you will also want to replace the fuel filter.
Now comes the fun... or a challenge
To start with you will need 2 sizes of fuel line ( go to a small engine repair shop) while you are replacing things you may want to buy a new primer bulb also.
to insert the fuel lines into the tank you will have to cut a tapered tail about 2 " long so that you can grab the fuel line with a needle nose and pull them through and out of the tank so that you can trim off the tapered tails. On one install the fuel filter and stick back into the tank, on the other trim the tapered tail off and pull the line back into the tank but leave about 1" sticking through the tank.
Now hook up you fuel lines to the carb and/ or primer bulb
Fill tank half full with fuel ... now test the installation if it doesn't pump fuel but instead you can hear it blow bubbles in the tank it is simple just reverse your lines on the carb / primer bulb
Retest if it works like it should you are ready to attempt to start it... good luck
Sep 08, 2009 | Homelite Garden
How do you replace the fuel filter on a homelite st 145? the hose snapped and the filter fell into the fuel tank. Thanks
Take the old piece of fuel line and have the vendor match the size. Buy 1 ft. so that you have a little extra to work with. Cut fuel line at an angle. This will allow for easier insertion into the hole in the gas tank. Feed the line through until you can pull it out of the opening where the gas cap is. Cut the line off square. Attach the fuel filter. Pull the line back through until it rests comfortably on the bottom of the tank. Assemble the trimmer. You will then get a more accurate measurement to the carburetor.
Jim
Jun 10, 2009 | Homelite Garden
Have a 18" power chain saw.
Fuel restriction could be dirty in tank filter, or high idle screw needs to be adjusted. Do this by turning it counter clock wise 1/8 turn at a time start and check for improvement after each adjustment.
Jan 04, 2009 | Homelite Garden
Garden Logo
894 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
