Question about HP Compaq 6735s Notebook
How to disable/enable touch pad on hp 6735s
Hi... i have a problem with usb optical mouse.. when i plug it in, its located in down left corner (where the start button is) an it wont go anywhere else... i think i need to disable touch pad on notebook so that usb mouse would work but i dont know where to disable it... im using windows 7
  • Greg Baldwin Mar 22, 2014
    From the quick research your model does not allow you to disable the touchpad. There is not button or FN key for it and the bios does not have the options in it for turning it off either.. Sorry
    actually correction... Dug a little deeper. It seems as though the laptop will disable the touchpad automatically once you install/insert a USB mouse.
    Top Expert:
  • HP Master
  • 14,162 Answers
Sir to keep it simple: first get the usb mouse to work by trying the other usb ports. also try a different usb mouse to make sure that mouse works. next: once the mouse works if you want to disable the touchpad the easyest way is to cover it up with a piece of paper. Less hassle. This way is you decide that you want to use it you just take the paper off. It is as simple as that. Good luck.
Posted on Oct 25, 2014
    Habit-Forming:
    New Friend:
  • 110 Answers
Well you will have to go to your bios settings first and disable you touch within the bios. plz let me no if you need help with the touch pad
or bois
Posted on Mar 21, 2014
Fixe_You
  • 1800 Answers
SOURCE: left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Posted on Dec 30, 2008
Techno-Geek
  • 38 Answers
SOURCE: hi HP Compaq Presario 2200
Dear Mr. Amr, (if this solution doesnt solve your problem, without rating the solution, please leave a comment and i will try to resolve your issue.)
Dear Mr. Captainjerry,
For your issue, please find attached the service manual for your laptop at this link. (*read complete email before clicking this link)
http://www.hp.com/ctg/Manual/c00226047.pdf
BUT,
If your laptop uses security chip protection, please continue reading as removing the battery won't help ... nor is there a reset jumper. If this model uses a Security Chip for access protection => once a password is set for BIOS access there is no way to reset it if you don't know the password. It will require a new security chip (which requires extensive soldering/desoldering skills and equipment, as the security chip is wave soldered to the board) or a new motherboard. You'll need to have the laptop serviced at an HP repair facility.
If you're comfortable with your soldering/desoldering skills, you may be able to buy the security chip here http://www.pwcrack.com/security_chips_compaq.shtml
Although they may not list your specific model, they can often get the appropriate chip if you give them a call.
Security-chip enabled laptops have EXCELLENT security => they're designed so that if you set a password your data is thoroughly protected against anyone who doesn't know the password -- including YOU.
The good news is that's great protection -- you can be sure that if the laptop was lost or stolen nobody can access your data. The bad news is that if you forget the password you're out of luck -- you also can't access the data. There's simply no recourse except to have the laptop serviced at an authorized repair facility ... they'll likely require proof of ownership; and it's not an inexpensive repair.
Hope that was useful. If yes, please rate the offered support.
Regards,
Techno-Geek.
Posted on Apr 16, 2009
1234s282
  • 144 Answers
SOURCE: Touch pad not working
Go to device manager
Right click the touchpad device
Uninstall driver
Reboot system
go here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-66690-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3795289
Reinstall touchpad driver
see if that helps
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Posted on Jul 01, 2009
marktyan
  • 40 Answers
SOURCE: hp 6735s wont shut down
you have a drivers hanging or software related error occuring
start the notebook
goto start > control panel > administrative tools> system event viewer
then sift thru the error messages you get under the system menu
look at the last time you shut down... submit the reports to microsoft and an explaination will follow to solve your error or hang on shutdown
Posted on Sep 28, 2009
bordiavineet
  • 50 Answers
SOURCE: touch pad not working nor mouse buttons
touch pad driver is download is your laptop.
see site and download your laptop touchpad driver
http://driversdownloadsfree.com/get.php
download mirror ok
Posted on Feb 26, 2010
How to turn the touchpad on and of?
IF IT IS A NEW HP LAPTOP LOOK FOR A BUMP IN THE LEFT SIDE TOP CORNER OF TOUCH PAD ( MOUSE PAD ) DOUBLE TAP ON THAT AREA THEN U WILL NOTICE A LED LIGHT GLOWING NEAR TO THAT...THEN TOUCH PAD IS DISABLED,DOUBLE TAP ON THAT BUMP TO ENABLE TOUCH PAD
Jan 07, 2014 | HP Computers & Internet
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
I want to disable the touchpad and use the external mouse exclusively
Some laptops don't have dedicated buttons but you can use Function keys (like Fn + F5 on Dell computers) to toggle the state of your touch pad. In the case of HP laptops, you can hold the top-left corner of the touchpad for few seconds and it will disable the touch pad - repeat this to re-activate it.
New laptop computers either have a physical on/off button to easily disable the touch pad or there's an icon in the system tray that lets you manage the various settings of the touchpad. If you don't have that icon, you can go to Control Panel -> Mouse Properties -> Touch Pad to enable or disable the touchpad.
The touch pad can also be disabled through the device manager. Type devmgmt.msc in the Windows Run box to start the device manager, expand "Mice and other Pointing devices", right-click and disable the driver entry that says Touch pad or likewise.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 30, 2011 | Toshiba Satellite P305DS8836 Notebook
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
When my new hp mouse pad locks, how do i unlock it without restarting the computer?
There should be a button above the pad or work your way using the keybord to mouse properties and go to the page that has the name of your track pad and select enable.
Mar 01, 2011 | HP Pavilion dv7-1020us Notebook
My mouse pointer not moving if i use touchpad, but if i use usb mouse it works well.
Try to press Fn (locate at the bottom left of the keyboard near CTRL )and at the same time tap F9 (on top of the keyboard), you will see the status if it's enabled or disabled, just tap F9 to make it enabled.
Feb 24, 2011 | Toshiba Satellite L455DS5976
My Dell N4010 Laptop with Windows 7 software indicated a message of "touchpad disabled", and I can not manipulate the mouse.
You are confused. Your touch pad is disabled, but if you plug a mouse into the USB port, your PC will find it and install its software and you will be able to use the mouse To re-enable the touch pad, click on the Windows ball at lower left of desktop, Control Panel, Mouse, Touch Pad, Enable Touch Pad.
Oct 18, 2010 | Computers & Internet
Emachines laptop e525 mouse pad not working at all so cannot use everything else starting up as normal
Look at the middle cover (above the keyboard). there are two buttons that touch the power switch, the one to the left enables/disables the touchpad. If it shows an orange light it is disabled. Just press it, and be careful not to hit it when turning unit on.
Jul 08, 2009 | E-Machines T5212 PC Desktop
HP Compaq 6735s Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
