Question about Joico Vero K-Pak Color Permanent Creme Color CCV Violet Corrector
Trying to tone out yellowy/orange hair
Would i use ccv violet corrector and 5 volume to tone out yellow/orange
Can I use 30 vol with matrix vlight bleach?
yes you could and tone with a violet base level 9 i did it and went fine if she wnt lighter you could add foil ???
Apr 22, 2012 | Cars & Trucks
I have natural lt brown hair w/ blonde highlights. I wanted a more uniform color and to get rid of the grey. I bought wella color charm 811/8n light blonde and used 30 volume developer. Left it on the...
Gray hair is resistant to accept color.....You might try to find one of 2 products: " Zotos Porosity Equalizer" from Sally's or any beauty supply store. Also, Clairol has a new formulation called "Gray Solution", where there is a cream added to gray hair prior to adding color. This is for next time you plan to color.
In the meantime, you may want to purchase Roux Fanci-Full Color Styling Mousse in either #19 or #18 to tone down the red tones from your local beauty supply or online.Good Luck
Jul 18, 2011 | Wella Color Charm Liquid Creme Haircolor...
Hello! i used the bright yellow prizm during my highlits and they became bright yellow! i tought it would give like a gold tone to the highlights but they were super yellow. so i applied bleach to my hair...
ok honey, first thing is don't freak, you will be ok. the only way to fix this is to go darker. with out a picture I'm going to do my best to help you. See if you can get a friend to help you do this. You will need to put the hi-lites in foils, try to get as much of the blond and as little of the orange as possible in the foil, coat with conditioner, and fold. this will keep them blond as I assume you want to keep them. Between the foils you will need to use a 5 or 6 ash based color, this will neutralize the orange color you have now. Use 10 vol developer or even 5 vol if your hair is in bad shape.leave on about 10 to 15 mins, rinse off a piece to check color progression, when it's a neutral brown you will need to rinse. I wouldn't leave it on more than 30 mins or you could end up ashy.
Jun 15, 2011 | Matrix Prizms Plus Conditioning Color...
My hair is yellow on top and orange on bottom from bleaching it. would wella regal beige T27 tone it to a light blonde?
no I don't think it would. A beige is a red violet base. if you are orange you need to use a blue or ash based toner and a violet toner for the yellow, this will counter act the un wanted pigment. Not sur what to recommend in wella. I use redken at work.
Jun 03, 2011 | Wella Color Charm Toner #T27
Wiring schematics for a kenwood kdc-mp145 to a 1998 ford ranger
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Sep 21, 2010 | Car Audio & Video
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
Need a wiring diagram for a clarion db185mp
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Dec 27, 2008 | Clarion DB185MP Car CD/ MP3 Player
Joico Vero K-Pak Color Permanent Creme Color CCV Violet Corrector Logo
113 people viewed this question
Top Joico Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Joico Health and Beauty Expert? Answer questions, earn points and help others
