Question about Jenn-Air JGR8750 Gas Kitchen Range
Jenn-Air control pad Bake/Broil/Clean buttons "crossed" after F! code
Had F1 code flash but has disappeared. Now pressing Bake results in Convection mode (convection fan icon comes on) even though its not convection model. Pressing Broil results in Bake mode. Pressing Clean results in Broil mode. Other keys are fine and oven is operating in the mode that comes on. Tried resetting twice by switching circuit breaker off for 2-3 minutes. Suggestions? Given range is 17 years old, reluctant to replace part(s) given cost of parts vs new stove. Okay to use as is? See how long it lasts.
  • 409 Answers
SOURCE: Convectin fan in Jenn Air Stove
sounds like the fan or motor is not working at all. have a technician replace it.
Posted on Sep 13, 2008
SOURCE: Jenn-Air electric range
my jen-Air has a problem with it continuing to beep. Ive tried to get it to stop by pushing all the buttons. When I pust the off/cancel button it just keeps beeping. Tried the stop timer button and same thing. When I turn on either the bake or convection bake button it automatically just shuts off by itself. It is approx 10-13 years old. HELP, or please tell me to get a new one.
Posted on Oct 23, 2008
  • 2692 Answers
SOURCE: 1985 jenn air electric range
http://www.jennair.com/customer_care/contact_us.jsp
Posted on Dec 29, 2008
mgprice
  • 744 Answers
SOURCE: F1 error code is displayed on my Jenn Air 8850AAW,
Hello, I am going to include a link which gives you a full list of error codes, once you have found the error code for you range it should just be a matter of changing the part...If you have any problem understanding what the error code refers to please feel free to comment again and i will go through the problem with you. Hope this helps...good luck!!! http://www.repairclinic.com/0078.asp#Back
Posted on Jul 08, 2009
protek480
  • 1714 Answers
SOURCE: Kitchenaid electric convection range - preheats
Put an oven thermometer in the oven on convection bake and check the actual temp inside. I'll bet it's not maintaining the correct temp in convection.
Posted on Jul 25, 2009
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Funny - didn't ask about a slide in electric kitchen range - was asking about my Jenn Air Stove. You deal with them, correct? Have a Jenn Air WW2780B that I can't seem to get working. It started...
I had a customer with the same problem last month and I believe it was on the same model as yours. Let me look in my database and I will get right back to you.
Warmest regards,Richard
Nov 01, 2011 | Jenn-Air SVE47100 Slide-In Electric...
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
I receive an F1 error notice when I cancel the bake setting.
Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
if you are handy you can remove control board ribbon clean in and replace..
Sep 27, 2009 | Jenn-Air Ovens
Jan 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
Jenn-Air JGR8750 Gas Kitchen Range Logo
22 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
