Question about Rotary Drills
How to I remove the chuck on a PSB 750 RCE?
I plan to replace the chuck with one from a PSB650 RE (or buy a new one from Bosch if necessary) however there isn't a locking screw inside the chuck.
  • Ralph Beales
    Ralph Beales Mar 22, 2014
    I have a brand new PSB 650 RE and a nearly new PSB 750 RCEhttp://www.bosch-do-it.com/gb/en/diy/too...
  • Ralph Beales
    These are identical bar the motors (one is 750W and the other 650W) Neither has any type of screw holding the chuck in place - see attached photo looking into chuck - so I\'m wondering if the allen-key-and-bash-approach is the way to do it.
rowdy45176
  • 2176 Answers
SOURCE: Can't remove old drill chuck. No screww head visible
I can't find that model number in their database but I would guess that the chuck that is on it now is for a non-reversing tool and therefore would not have the hole for the chuck retaining screw. As long as the threads are the same I don't see a problem putting it on. Let me know if I can help further. Dave
Posted on Dec 24, 2008
SOURCE: Can't remove the chuck on a drill.
There are one-way (non-reversible) and two-way (reversible) drills. Mine is one-way. Methods for chuck removal are different for these two types.
Procedure for one-way (non-reversible) drills:
Drills of this type have no chuck screw, so one have to hold the spindle with a wrench, than to sharply strike the wrench with a hammer to spin it off.
Procedure for two-way (reversible) drills:
Open the chuck up and in the bottom is a screw that holds the chuck on the shaft.The screw turns in a clock wise motion to be removed and then you can top the chuck off the shaft.
Posted on May 20, 2009
brewerstool
  • 141 Answers
SOURCE: Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Posted on Sep 23, 2009
harlan301
  • 205 Answers
SOURCE: New bosch psb 550 re with hammer action. Hammer
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Posted on Oct 15, 2009
  • 8 Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Posted on Dec 10, 2009
How do you remove the keyless chuck on a Bosch PSB600 RES drill?
Here's a link to an exploded view:
Bosch PSB 600 2 0603338003 Spare Parts
If you need more help - you should contact Bosch directly:
Contact Bosch
Apr 14, 2015 | Bosch Drills
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Bosch psb 750-2R
manufacturer can supply you with a new chuck. Mounting bolt is typically through the front opening into the back portion near the drive assembly
Jul 04, 2014 | Drills
Psb 650 re
You have wound the threaded section of the jaws fast the thread in the case so sorry the chuck is broken as the teeth will be damaged. Best replace it with a new chuck
Jun 18, 2013 | Bosch Drills
I have a Bosch PSB 500 RE elec drill and need to remove the chuck. Could you tell me how to remove the chuck please. Thanking you. Alan
Its been my experiance from working as a cabinetmaker/finish carpenter that chucks have been installed the same way. They are pressed in, What you need to do is either secure the chuck, or body to something solid. If the chuck, drive a lag bolt into something like a T-pole, [ thats what I use], or secure the body to a sturdy bench. Either way your gonna take a hammer , and, a block of wood, smack the opposing end. It will come apart, but dont break anything. You will need to do some configering with your tools, but be aware and watch whats going on.
Mar 19, 2011 | Garden
The keyless chuck on my "PSB 5000 RE" electric drill has jamed up and cannot be used. Can it be replaced or is the whole electric drill a throw-away?
chucks are screwed to the drill by a left hand theaded screw. try to get the jaws open enough to access screw then replace with new keyed jacobs chuck. they are brill.
Aug 12, 2010 | Bosch Garden
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
Hi, I let a friend use my Bosch 5600 PSE key less
you can't drill counterclockwise the bits are setup to drill clockwise and the chuck would become loose. try using two wrenches to free up the chuck then spray a little wd40 in it it is just bound up
Nov 05, 2009 | Microwave Ovens
Drills Logo
286 people viewed this question
Top Rotary Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Rotary Drill Expert? Answer questions, earn points and help others
