Question about Kingston Electronics - Others
Kingmax microSD cracked
Card short-circuited
  • Kingston Master
  • 3,320 Answers
Get a new one. Then read how to take care of it.
Posted on Apr 07, 2014
Reset asus memo pad kow to factory settings?
If you cant reset your phone normally try hard resetting it.
  1. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  2. Afterwards unzip it to your MicroSD card.
  3. In order to turn the device off press the Power button for a short while.
  4. First of all, download the "cleardata.zip". You can get it from support.asus.com (e.g. Asus clear zip )
  5. Afterwards unzip it to your MicroSD card.
  6. In order to turn the device off press the Power button for a short while.
  7. Select Clear User Data using the Volume buttons to navigate and Power key to select.
  8. When "Please remove installation media!" inforamtion appears on the screen remove the microSD card from your device.
  9. Success! The hard reset has just been performed.
If this doesn't work use the link below
ASUS ME176C Memo Pad 7 How to Hard Reset my phone HardReset info
Mar 17, 2017 | ASUS Tablets & eReaders
Read micro sd kingmax
If you read it with a computer (laptop or desktop), you can check it using Disk Management:
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. Is the SC card info exist in this screen?
Mar 03, 2014 | SanDisk 2GB microSD Memory Card
My Sansung laptop does not recognize the memory card for my camera.
A microSD device is a digital storage device used in many Mobile Phones Cameras and MP3 players. It is a smaller version of the standard SD memory card, about one-quarter its , and has a storage capacity that ranges from 128MB to 4GB. In order for you to read files inside the microSD card using your computer, you need either a microSD card reader or a microSD card adapter. Insert the microSD card into the microSD card reader and make sure that the card is properly connected to the device. Plug the microSD card reader into a USB port in your computer and wait for the computer to recognize the device. Use a microSD card adapter to read your microSD card if you do not have a microSD card reader. A microSD adapter basically looks like a standard SD card but is designed to accommodate a microSD card to fit the SD card slot. Simply insert the microSD card into the microSD adapter and then plug the adapter into the SD slot in your computer. Plug the SD card adapter into an SD card reader if the computer you are using does not have an SD slot. Consequently, plug the SD card reader into a USB port in your computer. Use your phone to read your microSD card. Plug one end of the USB cable that comes with your camera or phone to the mini USB port in your device and plug the other end to a USB port in your computer. When you are prompted that the device is recognized, install syncing software (if applicable). Many cameras phones and MP3 players can be connected to the computer without using any software. Navigate to the location of the removable drive.
Open the folder to see if you can browse the files in the microSD card.
Jan 14, 2013 | Samsung Computers & Internet
How to format when the 4gb kingmax micro sd class 4 HC can't be read
Right Click Computer, Properties, Manage, Disk Management. If it doesn't show up here the card is bad. If it shows up as Not Initialized, right click it and initialize it then right click and partition it.
Dec 21, 2012 | Electronics - Others
I forgot my password to my san disk 519mb sd card its asking for 8 numbers or letters how do i unlock it without losing infomation
download password recovery tool for memory card downlaod the password recovery tool and then crack your password
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
What is the maximum size microSD card that can be used?
The A520 uses SD cards. SD cards max out at 2GB in size. A microSD card in an adapter looks exactly like a SD card to the camera, and microSD cards also max out at 2GB. Anything larger is a SDHC or microSDHC card. While they will fit into the slot, they are electronically incompatible and will not work. So, the short answer is: 2GB.
Dec 20, 2010 | Canon PowerShot A520 Digital Camera
How do you manually open a memory card adapter?
Just bend it enough and the plastic will crack open or you can use something like a knife and run it along the perforated edge of the card. It actually pops open easily if you try.
Oct 13, 2010 | SanDisk 2GB microSD Memory Card
I put an 8GB microsd card (with an microSD to SD adapter) in may Pentax OptioX and when I open my camera, I have a short delay, then I receive an 'Memory card error'. What's the problem? Thank you.
The S5i uses SD cards. This means you can use microSD cards with an adapter. However, your 8GB card is actually a microSDHC card, which with the adapter appears to the camera as an SDHC card. SDHC cards are electronically incompatible with SD devices and will not work. You need to use SD and/or microSD cards, which max out at 2GB in size.
Sep 25, 2010 | Pentax Optio S5i Digital Camera
I have kept a password for my microsd card of nokia 5130 xpmusic.but i have forgotten it. is there a way to crack my password
Hi i havve the same problem i have an 8GB microsd in my 5130 and i restored my factory settings and my mem.card got locked so i dont know the password...PLEASE HELP WANTED!
Mail me at ashen_gck@hotmail.com
Mar 21, 2010 | Nokia 5130 Cellular Phone
Electronics - Others Logo
29 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
