Question about Apple Mac Pro 8-Core Two 2.8Ghz Quad-Core Intel Xeon/4GB RAM/500GB/16x SuperDrive/2600XT Server
Mac pro not turning on
Machine turn's off after switched on, with on indicator light coming on.
    Novelist:
  • 206 Answers
WOW, could be a ton of different possibilities.
I'd start with the power supply.. Most common to die.
Might cost you a arm and a leg. not sure what power supply the mac pro takes - Good luck - Vote yes if this has helped you..
Posted on Apr 08, 2014
Not turning on
Look on the underside of your Mac and press the button that tells how much life is left in your battery (it has 4 green LED indicators). If none of them light up, your battery may be dead/not functioning.
Or...
Your memory/RAM might have gone bad. Has the memory/RAM been upgraded? If so, replace it with the original memory that you replaced. If you only have the factory memory in it, then it might be something else.
Aug 31, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Colored circle comming up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 28, 2014 | Apple Computers & Internet
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
The FLO is lit up on my Pro-form restoration 5.1. how do i fix it?
The error code FLO indicates that there is NOT enough water flow through the system to operate the spa and make the heater turn on.
Check your spa filter by removing it. If the heat indicator comes on then you can be assured your filter is too dirty.
If the heat indicator light does NOT come on after removing the filter then you need to check the PRESSURE SWITCH by by-passing the switch and see if the heat indicator light comes on. If it comes on after jumping the two wires together that go to the pressure switch then you know you have a bad pressure switch.
Also, check the gate valves on either side of the pump to make sure they are completely up and you have good water flow.
Rod
US Parts Center
888-521-6183
Feb 06, 2013 | Pool & Spa
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
Hi i have a macpro 13" not turn on ,the pwr adapter light its dim, i replace the adapter and continue not turn on . its not a new mac and was working few hour ago
If the power supply is dim it indicates a motherboard problem and is loading the charger down. The only option is to have a computer tech who is familiar with Apple Notebooks to check it out with an estimate.
Jan 07, 2011 | Apple MacBook Pro Laptop Computer with...
When I am charging the mac book the orange light is turning to green then orange again.. why is it like that? how can I repair it?
This may indicate that your battery is going bad and not holding a charge. Try inserting a different battery and see if the light stays green.
Jul 12, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Blinking power light and the fan comes on, what's the problem
it sounds as if your RAM is slightly loose what I would do is open up the machine (with it switched off, of course) and reseat the RAM (i.e. take it out and put it back in. Hope this helps. If not send me a comment indicating the rate of white lights (i.e. 3 lights then a break)
Nov 05, 2009 | Apple Power Mac G5 Desktop
Can not turn tv on--light keeps blinking on the switch, but will not come on--no picture
Depending on TV, pilot light flashing indicates a problem in circuit. Get pro/tech help
Apr 21, 2008 | Televison & Video
MacBook Pro Black screen and shining sleep indicator
is the battery fully charged? try plugging it in then press the power button again.
Jan 10, 2008 | Apple MacBook Pro PC Notebook
Apple Mac Pro 8-Core Two 2.8Ghz Quad-Core Intel Xeon/4GB RAM/500GB/16x SuperDrive/2600XT  Server Logo
119 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
