Question about General Electric Dryers
Felt front gasket torn
Felt gasket on dryer is torn up. dpsr610egotw- mod.#
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Your local appliance parts store will have a felt gasket kit with all you need to repair it. If you aren't handy, you may want to call a technician.
Posted on May 19, 2014
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: dryer makes loud sraping noise,
Hello Moldiegold,
You've already identified the problem but in order for me to assist you with a replacement gasket set, you will have to proivide me with the brand and model number of your dryer..
Posted on Sep 28, 2008
  • 67 Answers
SOURCE: Maytag Bravos dryer tearing the "felt ring" on front of drum.
Mostly likely the cause was the skid pads came off or were missed aligned. You could have also jarred the drum but it doesnt matter because you want it fixed. So take off the front of the dryer after calling your local maytag dealer and making sure they have the felt, skid pads, belt, and rear rollers (just in case you find more problems).
Once you have this apart make sure you clean it good, take out the lint catcher and vacume all of the lint. No reason to put back together a nasty dirty dryer. Make sure you check the rear felt carefully and the rollers. This is a very simple job and shouldnt take more than about an hour. Make sure you take the door off first then the front panel and you have someone to help hold your tools while you think. Have fun
Posted on Aug 15, 2009
mrfixit3667
  • 262 Answers
SOURCE: Clothes are getting caught and torn
yes. your drum gasket is bad
Posted on May 24, 2010
Testimonial: "Thanks for your help. I will order from Sears"
Leaving spots on clothing
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Dec 24, 2010 | Kenmore Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
I'm finding pinholes in my clothing.
I'd be more suspicious of what you're putting through the wash, rather than the machine.
Aug 01, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Black stains sticking to white clothes on washing
Rollers
Rear seal
Front glides
Front seal
Jun 08, 2009 | Washing Machines
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Maytag Dryer Mosel #MDE6700AZW
you will need to remove the front panel and the front bulk head. after that you will see that there are clips that need to be pushed down to hold the fabric (felt) down. You need to make sure that the felt isn't torn. If it isn't torn then all you need to do is take a flat head screw driver pry the clips up and put the felt back on and push the clips back down
Dec 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Torn clothes
Rollers
Rear seal
Front glides
Front seal
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
81 people viewed this question
Top General Electric Dryers Experts
Tim Whalen
Ned Halaweh
Ned Halaweh
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
