Question about Ovens
Neff b1861 oven fan and interior lights not working on Circotherm settings
Oven fan and interior lights only work on Thermoroast setting. Replaced blown element at rear which surrounds fan and this now works ok. Obviously not fan motor because everything works ok on thermoroast setting ie fan runs and lights come on . But it is supposed to alternate between fan element and grill element in thermoroast setting but just carries on running with top element on until correct temperature obtained and power is cut. Have checked continuity of wiring as far as I am able and there does not appear to be any problem with the main controller switch contacts. Any ideas please
    Problem Solver:
  • 8 Answers
Sounds like the control switch to me. if you have already taken it apart it's the switch with the most wiring.
Posted on Mar 22, 2014
barkencoa
  • 3463 Answers
SOURCE: Neff faulty Fan
Hi.
I would not think that both fan and element are faulty, although it is possible.
if it has a timer make sure that it is on manual and not on auto, as this would stop the oven working.
Other possible fault is faulty main oven selector switch.
Hope this helps. Please do not for get feedback .
Thanks.
Posted on Nov 25, 2008
apart4u
  • 213 Answers
SOURCE: neff circotherm doudle oven main oven fan working
For all Free appliance repair videos visit our VIDEOTUTORIALS1, If the fan motor in the back of the oven is going round and thetemperature light is on (normally little red light), but there is no heat thenyou will probably need a new oven element, these are generally very easy to fitand readily available from our website these can be tested with a electricmeter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then youneed To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
2coolrick
  • 560 Answers
SOURCE: Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Posted on Jun 05, 2010
heatman101
  • 43501 Answers
SOURCE: Top oven (and Grill) have stopped working
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
SOURCE: Neff U1452 circotherm oven element problem.
install a new fan again and try again
Posted on Sep 13, 2012
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Oven Bulb.
have to call service tech
May 15, 2010 | Neff B1861 Single circotherm super...
Oven not heating up
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Sep 22, 2009 | Neff B1432 Single circotherm plus Electric...
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Neff B1861 Single circotherm super...
Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Nov 28, 2008 | Neff B1432 Single circotherm plus Electric...
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
121 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
