Question about Radio Communications
Peterbilt wiring diagrams
No low beam
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
I could wire it but you are better off taking it to a shop that works on trucks.
Posted on Jun 05, 2014
My 2011 Chevy Silverado low beams are not working everything else works but the low beams and someone please give me a diagnosis thanks.
Your low beams are controlled by the Vehicles BCM - body control module . The BCM energizes the HDLP LO/HID relay located in the under hood fuse box , sending B+ voltage to fuse's # 12 & 16 both 20 amp . LO HDLP - LT & LO HDLP - RT , These are B+ voltage for low beams . Your headlamp low beam relay could be bad or if the BCM isn't energizing it could be a switch problem . Do you know how to do basic automotive electrical testing using a volt meter . Videos on youtube ,plus video's on reading wiring diagrams .You can find free wiring diagrams at http://www.bbbind.com/free_tsb.html Also watch testing relays
Jan 18, 2017 | Cars & Trucks
2004 378 Peterbilt,low beams on but high beams also on faintly
Usually mean there's a bad earth. Most automotive electrical problems stem from poor earths.
Mar 23, 2015 | Cars & Trucks
Right low beam stopped working, where is the ground wire run to check that
Do the high beams work?
The ground point is on the apron ( the inside of the fender, just behind the headlight). There is one on each side. From the wiring diagram, there is just a splice connecting power to the lights in parallel for the high and low beams, but the grounds are separate.
If the RH high beam and the LH low beam works, then it is not a ground problem. You could just tap the LH wires to power the RH, but I think that if you look closely the connector for the bulb is probably melted. If that is the case then you will have to splice on a new connector.
The colors are as follows:
RH --> low beam power ( light blue)
LH --> low beam power (white OR light blue)
BOTH high beams --> ( red/white stripe)
Ground --> Black
Sorry, The diagram is too large a file to upload.
Jan 12, 2014 | 2000 Mazda Millenia
1999 harley softail have no low beams
Hi Johnny, check your hi/low beam switch for continuity and for a free wiring diagram please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Jan 23, 2013 | Harley Davidson FXSTS Springer Softail...
I have a 94 Honda Civic EX, and the right low beam headlight does not work. The bulb was bad, and I replace it, but still didn't work. The high beam works, and I can hook the low beam connector to the...
there are fuses for each light, high and lo beam. the grounds are grounded at all times, I dont know what you mean by open seeking. its wired like every other car. Right low beam is fuse 21 Red/White wire should be hot if fuse is good. I dont know what you mean by hooking low beam connector to battery? check fuses.
Sep 09, 2011 | 1994 Honda Civic
Need the wiring color diagram for a 1991 Suzuki Sidekick at the headlight plugs. i'm trying to wire in 100/80 Heliolite bulbs and yes I know they are off road only bulbs. i have the relays and a fuse and...
should be three wires one ground one power for low beam one power for high beams
unplug connector
take a test light (if dont own one buy one there real cheap and useful) clamp test light to good ground turn on lights on low beam probe wires in connector until test light lights this will be low beam power
no switch to high beams should have power on other wire
Jun 09, 2010 | Cars & Trucks
Low Beam Drivers Side doesn't work ... low voltage,
Power for the headlights on the Left side (High and low beam.) comes from the same fuse... The ORANGE wire and the ORANGE/BLACK are the same, they connect in the harness. If you only lack the 12v to make the light work connect them at the headlight assembly.
If your low beam also lacks ground the Left low beam ground is shared with the right low beam ground... Run a wire from left low beam DARK BLUE to right low beam DARK BLUE/WHITE.
If its not working now then your cursed, seek a witch doctor.
May 23, 2010 | 2004 Buick Regal
Headlight wiring diagram 95 honda accord lx
Red/white is left high beam and red/yellow is left low beam. Red/orange is right high beam and red/green is right low beam.
May 24, 2008 | 1995 Honda Accord
Radio Communications Logo
197 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
