Question about Toshiba Satellite L305-S5933 Notebook
Toshiba Satelite L300 PSLB8E screen turns white
Hallo there I have a Toshiba L300-0E007EN when shitched on the windows load before the desktop the screen just turn white
    Top Expert:
  • Toshiba Master
  • 20,130 Answers
Test with an external monitor.
Posted on Mar 21, 2014
TimeDefensiv
  • 746 Answers
SOURCE: display drivers for windows xp toshiba satelite
Dear! Go to this link http://www.laptops-drivers.com/bios/acpi-flash-bios-for-toshiba-satellite-a135-7404.html and download your driver free and save it on your laptop.
Posted on Aug 30, 2009
prashanthcl
  • 460 Answers
SOURCE: Toshiba Satellite Pro L300 PC Notebook Blank blue
It is a problem with Hardisk & RAM.first you can checked it reinstalled the OS.if problem does not solve then checked it repace the another RAM & hardisk.
Posted on Oct 26, 2009
BLAZZ81
  • 281 Answers
SOURCE: Beeps when I turn it on then no response
sticky keys? bad keyboard,,
did it get wet?
I would get a new keyboard off ebay $10-$30
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=toshiba+satellite+L300+keyboard&_sacat=See-All-Categories
Posted on Nov 23, 2009
  • 1705 Answers
SOURCE: replacing keyboard on Toshiba Satelite L300
I'm assuming you've already managed to lift the keyboard to expose the cable and ribbon connector on the motherboard.
As you can see the ribbon looks as though it just slot into what looks like a rectangular block.
The top and rear of the connector block is one piece and needs to be CAREFULLY lifted, it only comes up and eight of an inch or so. This releases the ribbon. The block stays in situ.
Here's a Youtube video which shows a similar connector :-
http://www.youtube.com/watch?v=GcM9knr_P4Q
It may be the same as yours,
Here's another youtube clip describing the kind of connector I tried abover.
http://www.youtube.com/watch?v=l2ii1PIHaCM&feature=fvw
Posted on Mar 31, 2010
virtual_a
  • 531 Answers
SOURCE: My TOshiba satelite pro L300
Hi
When a computer powers up the basic control program (BIOS) first addresses the graphics, then the CPU, then the memory, then the hard drive, then other devices.
If you see nothing at all on the screen, then it is probably a problem with the graphics card.
Check the lights on the front of the laptop. If you see a power light but no activity on the hard disk activity light, then the boot is failling at the 1st stage, before it even reaches the hard disk stage. this means a graphics problem.
If the hard disk was preventing the computer from biooting you would see the first 3 parts of the boot procedure on the screen before it stops at the hard disk stage.
Remove the battery. Connect the power cable without the battery and try to boot. If it boots, the battery is the problem.
Connect a desltop PC VGA cable to the laptop's VGA port and connect it to a desktop PC monitor and send the image to the external monitor by pressing th Fn key simultaneously with the Function key with a picture of 2 monitors (normally F5, F6 of F7). If the image appears on the external monitor, the graphics card is ok.
If the graphics card is OK, then the problem will be a faulty LCD Panel, LCD Panel Power Inverter or LCD Panel Cold Cathode backlight. If not then the problem is the graphics card.
Ask a technician to test and replace any of these faulty parts, if necessary.
If it is the graphics card, then the repair is either Ball graphics Array Reflow or Reballing, both of which can be expensive, have a marginal success rate and the fault can reoccur after repair.
Only a specialist with an Infra Red workstation can fix the graphics card,. typical repair warranty is 3-6 months. If it's too expensive to fix, it may be better to buy a new laptop.
I hope this helps.
Posted on Aug 24, 2011
Bios password toshiba satelite l300
Method 1 (Flash BIOS)
Flash BIOS for Satellite L300-ST2501
Flash BIOS for Satellite L300-ST3502
1. Remove the battery and don't turn on the laptop (a minimum of one day or more). To remove electric current, which is still stored in the laptop. Based on experience, can turn a normal laptop, try to enter windows.
2. Download Flash BIOS slb0v150.exe then open the file, select Install, and select Install from Windows - OK.
Flash BIOS can remove the BIOS password
Method 2 (Manual)
source image : bios-repair
With solder, remove the BIOS IC, wait about 10 seconds, then plug it back. To remove the BIOS IC, you must remove the screws down and the LCD.
I hope this information helpful.
Oct 20, 2011 | Toshiba Satellite Pro L300 Notebook
I want all the driver for toshiba satellite L300-1FB Laptop
Below is a direct link for your L300-1FB.
Satellite
Short Model no: PSLB8E
Hopefully this helps..
Thank you for posting..
Jul 08, 2011 | Computers & Internet
Need audio drivers for toshiba l300 modle no PSLB8E-05X00HAR
All you will ever need for your laptop is to be found at
www.toshiba.com
Hope that helps.
Feb 18, 2011 | Computers & Internet
Hi.....I can't get my Toshiba Satelite M200 to shut down. The blue screen keeps stating shutting down but it goes on for hours. I am using Vista
Windows is so corrupted that it can't shut down properly. The only way to fix that is to save your data and reinstall. And be very careful what program you load after that because it was one of them that has corrupted Vista so load them one at a time with serious testing in between.
Dec 21, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satelite Pro L300 won't boot up properly.
firsly start your computer in safe mode then do syatem restore .if problem will not solve then mail me at vicky.akon11@gmail.com
Jun 26, 2010 | Toshiba Satellite Pro L300 Notebook
I have no driver CD of toshiba satellite L300-257 system unit.what ido for it.
Drivers for that model of laptop can be downloaded from the link below. The actual short Model # is PSLB8E
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU&mode=allMachines&action=search&teddProduct=784&selShortMod=780
Robert from Blitware
Jun 22, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro L300 PC Notebook Blank blue screen. can't reach to desktop after loading windows. it have vista premium
Oct 26, 2009 | Toshiba Satellite Pro L300 Notebook
No display/monitor problem? When I turn on my Toshiba Satellite pro L300, I can see the Toshiba logo, bios menu, windows loading logo etc, then when it loads my desktop, nothing! No display, no graphics...
When you press power button press F8 key then enter in enable vga mode.
Then go to display proeprty and set screen rsolution to 1024*768 then apply.
Then check.
Aug 20, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L305-S5933 Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
